Alrighty guys. Got 3 weeks to make $1000 to have enough money to get my car painted. Spent all last weekend cleaning out my garage and I've got TONS of parts. What I have list is a fraction of what I'm willing to sell. Prices listed DO NOT include shipping.
IF you don't see what you need here please PM me. Chances are I have it tucked away in an bin. Don't hesitate to ask me about ANY part... If I don't have it I can generally point you in the right direction.
All my prices are negotiable and I will give discounts for buying up multiple parts. Here we go.
1. Good Center Console 8 out of 10 condition (Good Vinyl - Small Amount of Bubbling in the center) - SOLD
2. Stock M20B25 Motronic 173 ECU - $25
3. (2x) E30 Gauge Surround Trim - $5 each
4. E30 Lower Gauge Trim - $5
5. E30 Tan Kick Panels - $10
6. E30 Stock US Grills - SOLD
7. E30 Sun Visors - $10
8. E30 Black Kick Panels - $10
9. E30 M42 Intake Boot (Great Condition) - $5
9.5. Late E30 Radiator (Good Condition) - $40
10. E36 Aluminum Thermostat Housing - $10
11. E30 Remanufactured Steering Rack w/ Tie Rods (Both Good - All Less than 1k miles) - SOLD!
12. (2x) E30 Late Model Fan Shrouds - $5 each
13. E36 Fan Shroud - $5
14. E46 3.38 Stock Diff (has 120k miles - output shafts are leaky - 4 bolt flange) - $100
15. E30 Stock Mirror - $5
16. E36 4dr Window Motors - $10 each
17. E30 M42 Coil Packs - $20
18. E36 Manual Pedal Set - $20
19. E30 M20B25 Valve Cover (CLEAN!) - SOLD
20. (2x) E30 "iS" Trunk Spoilers - BOTH SOLD!
21. E30 M20B25 Oil Cooler (missing 1 line - 100% straight) - SOLD
21.5. (2x) 8in MTX Road Thunder Sub Woofers - $10 each
21.75 E30 325i Stock Springs (Front & Rear) - $10 for fronts / $10 for the rears.
22. Magnaflow Stainless Muffler - 2.5in -> 3in - SOLD!
23. Early E30 Driver Side Tail Light (Good Condition / No Cracks) - SOLD
24. Late E30 Driver Side Tail Light (Good Condition / No Cracks) - $10
25. E46 Fan Clutch (Good Condition) - $20
26. E36 (92-94) ABS Pump (Good Working Condition) - $20
27. E30 ABS Pump (Good) - $20
28. E30 Alternator (Good) - $20
29. E30 Subframe - $25
30. E30 PS Pump (Good)- $20
31. (2x) E30 Thermostat Housings - $10 each
32. E30 Starter (Good) - SOLD
33. M20B27 2.7l Crankshaft - Great Condition - $25
34. E36 Non-Vanos Motronic 403 ECU - $40
35. Late E30 Damaged Fog Light (inside the ellipical piece is loose) - $10
37. Late E30 Bumper Strips (Full Set) - $40
(All pieces have some busted clips but they all have enough good ones to mount securely, the middle back bumper piece has a small spot where someone backed into it but it is hardly noticable.)
40. E30 Center Console (7 of 10 condition - missing some vinyl on lower left corner / back ashtray area) - $10
41. Late E30 Tail Light Set (Great Condition!) - $40
42. E30 MTech 1 Steering Wheel (5 out of 10 condition - Leather is dry and worn) - $30
43. E30 Stock 4 Spoke Non-Airbag Steering Wheel - $10
46. E36 A Pillar Cover for 92-99 Coupe (Great Condition) - $10
47. E36 Manual Driveshaft (Center U-Joint Good / Rear is good but a little notchy) - $40
48. E36 325i Front Spindles / Rotors / Brake Calipers & Carriers (Bearings are Good)- $50
49. E36 1996 328is Dual Mass Flywheel - $40
51. Late E30 Fuel Pump (Pulled from a 89 325i - missing sock) - $40
52. E36 Getrag 250G - $100
54. E30 M20B25 2.5l Cylinder Head w/ bent valves - Good Core / Rebuildable - $50
55. E30 M20B27 2.7l Cylinder Head (Good but dirty as hell) - $50
58. (3x) E30 Tape Decks (without radio codes) - $10 each
59. Awia CD Player - $25
60. Pioneer CD Player - $40
61. Early E30 Radiators - $25 each
62. E34 M30 A/C Compressor Seiko (Good - may work on E30s as well) - $40
63. E46 M54 Engine Cover - $10
67. E30 Sealed Beams - $10 each (2x passenger side and 1x driver side)
69. Misc E36 Window Switches (small base) - $10
70. Late E30 Check Panel (Airbag) - $10
