FS: M52 Crank, S50 Crank, Whole M20, and Parted M20 (327i goodies)
  • Overlord475
    • Dec 2010
    • 799
    Hey guys,
    I've got some parts left over from a stroker build that I started before I decided to go with an S50.
    #3: Running M20B25 w/ 230k
    This motor IS NOW OUT out of my DD to make room for an S50. The engine pulls hard and of my 3 M20's is probably the strongest of them all.
    ***EDIT: Also, thinking about pulling all the parts off of my running M20 to make up a 327i stroker kit. If you're interested PM me.
    This is the donor car (1989 Delphin 325i):
    Iphone Video 1: Acceleration
    Iphone Video 2: Highway Cruising RPM Speed / Temp / MPG
    #4: Parted M20
    This is a spare b25 that I bought to start a 3.0L stroker build but have since purchased an S50 swap. Unknown donor and mileage. All parts are unverified and are at your risk to buy. Hints the cheap prices on certain parts such as alternator, power steering pump, etc.... The timing belt was still under tension and the head gasket was still good.
    *****All Prices are shipped except the head, intake, oil pan, and block
    *****Prices are fairly firm as I will mainly be using USPS flat rate boxes which start at $10 and up.
    Alternator (no pulley) : $40
    Intake (b25) : $60 + Shipping
    Throttle body (b25): $40
    Exhaust Manifolds (b25) : $20
    Wiring Harness: $35
    Pulley Wheels: $10
    Crank Wheel: $15
    Valve Cover: $40
    Fan w/ clutch: $35
    Oil Pan: $50 + shipping
    Thermostat Housing w/ sensors: $30
    Power Steering Pump w/ bracket: $35
    Oil Pump: $30
    Waterpump: $20
    Oil Filter Housing: $35
    Engine Mounting Brackets: $40
    Timing Belt Covers (2pc): $30
    Block: $100 +shipping (whole)
    or Parted.....
    Crank: $25 + shipping
    Rods: $40
    Pistons: $60
    Block only: $50 + shipping
    Note: At some point there was water in cylinders 3 and 6, but was not present when the head was pulled. This was probably due to condensation coming through the open exhaust side valves as the exhaust manifolds where not covered when I bought the motor. However, under inspection the corrosion and carbon build up is only on the surface of those cylinders and the cross hashing can still be seen on the clean cylinders. Bore out the block while you're stoking and it should be great. Also it does not fully crank. Can be cranked about 60 degress and the binds up. If I have to part the block I will look into why. I was not concerned as I was going to brake it down anyway.
    Again, prices are fairly firm as I will mainly be using USPS flat rate boxes which start at $10 and up.
    ***** Will trade for:
    Manuel All-Aluminum Radiator
    IX Booster
    735i MC and Res
    Crack Free Dash's (Looking for 2)
    E36 M3 ZF 5 Speed Trans
    E30 M3 Drive-shaft
    S50 Performance Parts
    Thanks
    --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
  • e30gentry
    • 608
    isnt there a guy somewhere on here who make the adaptors for fitting an m5x or s5x crank?
    • Schwarz325
      • Aug 2009
      • 487
      is that a m20 crank (trigger) wheel?
      • trackjunkie21
        • Jan 2010
        • 3962
        Sorry if I missed the price, but how much for the complete m20?
        Originally posted by Wh33lhop
        VANOS: sometimes you just need to go full retard.
        • Overlord475
          • Dec 2010
          • 799
          Yes sir: http://r3vlimited.com/board/showthread.php?t=153911
          Ireland Engineering also sells them for $60 (though I've heard stories about theirs), but the best quality adapter is from Metric Mechanic.
          If you're referring to this picture:
          Then yes, all of the parts in the Ad are M20b25 parts except the two E36 cranks.
          Sorry, no you didn't. I did not post one yet because it will be 3-4weekd before the motor is actually pulled.
          But I'm thinking $475 + shipping (with all accessories)
          • artoo93
            • 909
            pm'd
            Some people just need a sympathetic pat...
            on the head...
            WITH A HAMMER!!!
            • Danny
              • 14216
              This is an excellent for sale ad.
              • Overlord475
                • Dec 2010
                • 799
                Thanks man
                Head- Pending
                S50 Crank- Pending
                B25 Crank Wheel- Pending
                • green
                  • Dec 2010
                  • 128
                  PM'd.
                  • Overlord475
                    • Dec 2010
                    • 799
                    All PM's replied.
                    Also, all shipments will be postponed until the Blizzard warning here in OK passes, ha
                    • Overlord475
                      • Dec 2010
                      • 799
                      S50 crank sold!
                      Pending:
                      Head
                      M52 Crank
                      • e30gentry
                        • 608
                        M52 crank still for sale?
                        • Overlord475
                          • Dec 2010
                          • 799
                          M52 crank has some interest but is still up for grabs,
                          PM me if interested
                          • Overlord475
                            • Dec 2010
                            • 799
                            S50 Crank is Sold
                            885 Head is Sold
                            Everything else is still up for grabs!
                            • Jand3rson
                              • 37587
                              Do you have the single mass flywheel from the M20?
