FS:my bunch of good parts forsale thread!
  • atldohc
    • Nov 2008
    • 359
    i have a lot of stuff lying around that i wont be using anymore so im going to start putting everything into this thread. as always if you dont like the prices just shoot me an offer through pm.
    -e36 m3 cooling fan/clutch. i never tested it but was from a good running car $25
    -SOLD e30 1990 325is cooling fan/clutch.
    -s52/m52 intake manifold. $60
    -SOLDe30 1990 325is airflow meter. SOLD
    -SOLD!e30 airbag model steering rack.
    -SOLD90 325is oil cooler.SOLD
    -SOLD!m50 fuel rail with pressure regulator.
    -90 325is brake booster. engine swapped so im not using this anymore but worked great. $50
    -e32 master cylinder. ive never tested this one as it doesnt fit my brake lines. as you can see in the picture the line on the left is a little bigger than the one on the right. $20
    -ix/e32 brake booster firewall spacer. for those swapping boosters and opting to use the factory spacer. this ones aluminum which i thought was pretty cool. $15
    -jegs brake vacuum reserve canister. another option for those engine swapping with small boosters and wanting extra vacuum assist. worked ok for me but i ended up going to an e32 unit. $25
    -90 325is brake master cylinder. worked great for me. $25
    -SOLD90 325is front subframe.SOLD
    -SOLDm50 obd1 intake manifold.SOLD
    -SOLDe36 oil pan.
    -SOLDlate model radiator.SOLD
    -ebay cat back exhaust for 325i. i adapted this to my 24v exhaust system that i cobbled together, so you may have to make some modifications to get it to fit your car better. the welds are not the greatest and there may be some minor defects, ie scratches and i bent the tips down to fit my valence cutout better, but still definitely very usable and sounded great. would prefer pickup as its pretty big and heavy, but will ship at buyers expense if they choose to do so.
    please pm if interested in anything.
  • atldohc
    • Nov 2008
    • 359
    bumpity
    • atldohc
      • Nov 2008
      • 359
      ttt
      • atldohc
        • Nov 2008
        • 359
        Bmp
        • atldohc
          • Nov 2008
          • 359
          bump
          • atldohc
            • Nov 2008
            • 359
            pms responded to
            • e30rapidic
              • 2167
              don't hesitate to buy from this guy....a good seller to deal with
              '87 325ic, powered by S50.
              • atldohc
                • Nov 2008
                • 359
                appreciate it rapid. hope to do business w/ u again. :) other parts still fs
                • atldohc
                  • Nov 2008
                  • 359
                  bmp
                  • atldohc
                    • Nov 2008
                    • 359
                    bmp for parts added
                    • atldohc
                      • Nov 2008
                      • 359
                      some more parts i have
                      -SOLDrear camber/toe correction kit bolts,nuts, and washers. just missing the little slotted squares that weld to the subframeSOLD
                      -obd2 fuel rail cover(the little cutouts fit over obd2 intake manifold runners)
                      -obd2 dipstick tube and dipstick
                      -obd2 fuel rail
                      -SOLDset of stock basketweavesSOLD
                      -obd2 ignition coil wiring harness
                      can get pictures of anything the buyer is interested in. if interested in anything just pm me as i dont check this thread often!
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        Will to sell one of the M50 throttle bodies by itself?
                        • atldohc
                          • Nov 2008
                          • 359
                          sure but do you already have an obd2 intake manifold? i believe the gaskets are different and it may be easier to just run an obd1 throttle body, which i may have one of as well. i cant remember if i sold it already but i can check tomorrow if youd like. just shoot me a pm
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            PM sent.
                            • atldohc
                              • Nov 2008
                              • 359
                              SOLD basketweaves. SOLD
