Classified Forums - Read this first!
Here are a few simple guidelines for this forum. Failure to follow any of these rules will be grounds for your thread to be closed.
Post your information
Post as much info as you can. Say where you are located, where the part is located, the best way to get in contact with you, if you are willing to ship, etc.
Post the item's information
Post as much info as you can. A price must be posted, as well as pictures of the item(s). Post as many pictures as you can, even if it is a common item. A picture tells a thousand words, but it can also conceal another thousand. Links to hosted galleries of images are acceptable, links to eBay and/or Craigslist are not. Once the item sells, please do not edit your ad to remove the price. Many people search through old ads to get an idea what their item may be worth.
If listing a car, post:
-The year and model
-An accurate mileage. If the odometer is broken, post what it reads currently and how many miles you believe it has
-Any aftermarket modifications
-Any known issues or damaged areas
-A price
-As many pictures as possible of every area
If listing wheels and/or tires, post:
-The brand and model
-As many specs as you can, including but not limited to tire size, tread remaining, wheel diameter, width, offset, bolt pattern and centerbore, if multi-piece the lip, barrel and center size. If they have been redrilled post the original bolt pattern and where it was done.
-Any imperfections, including but not limited to curb rash, bends, cracks, repaired areas, scratches. For tires, note any gashes, bubbles, cupping or curb rash
-A price
-As many pictures as possible of every wheel
If listing parts, post:
-What brand and what models it can be used on
-An accurate description
-How long it/they have been used for
-Any imperfections
-A price
For miscellaneous items, post:
-A detailed description of the item
-How long it/they were used for
-Any imperfections
-A price
For WTB threads
-Be as detailed as possible.
-List exactly what you want, what variations you will accept, colors or materials, etc.
-Post what you won't accept. This includes imperfections, colors, models, etc.
-Post a price range of what you are willing to pay (typically based on condition).
-Post where you are located and if you would prefer local pickup.
In case the point was not made, everything being sold on this forum must include a price and as many pictures as possible.
-This is not eBay or Craigslist (or any other buy/sell/trade site). Do not post links to those for your ad. The same goes for linking to ads on other forums... either post your information here or have your thread closed.
-Feeler threads are not allowed. If you're not sure about selling it, don't post it.
-Cross-posting within the R3VLimited forum is not allowed. Choose a single subforum for your ad.
-If listing your item for trade, post what you are looking for, what you feel your item is worth, if you would like cash back or if you have cash to put on top.
-Thread crapping is not allowed. If you're not interested in purchasing the item for sale or have nothing positive to add, stay out of the thread or be prepared for a time out. If you complain about the time out, it will be extended.
-Threads can be bumped a maximum of once per day (24h). You are allowed to respond to others more than once a day.
-If listing multiple items, post them in one thread. Exceptions are cars and wheels.
See more
See less
Fully Built TurnKey Megasquirt EMS in Motronic 55pin Case
This topic is closed.
    Wasted spark option
    MapDaddy option
    Based on the MS2 Microsquirt Module
    Running MS2/Extra 3.3.3 - with startup tune
    Idle Control Circuit for 3 Wire ICV(Stock Late Model)
    Main Relay Activation Circuit - No need to rewire any relays
    Relay Circuit for General on/off
    Launch Control Circuit
    Two PWM Controller Circuits for Boost Controller, WI, ?
    Up to Four Ignition Drivers - Easily Upgradeable to Wasted Spark - Currently configured with 1 BIP373 for single coil
    Up to Four Injector Drivers (3 installed) for full 4cyl - 6/8cyl Semi Sequential Injection
    250kpa Map Sensor - Upgradable to MapDaddy
    Small Proto Area
    Jumpers for Stock TPS(with idle/cruise/WOT signal) / Variable TPS
    Jumper for 5/12v out for MAF support
    Jumper for Bluetooth support
    Diagnostic LEDs for Relay, Idle control and PWM Controller Circuits
    Power Jack (same as stim power supply) for out of car updates
    $650.00*
    Locals are welcome to take it for a test drive in your car :)
    Trades considered ;)
    *Built into your core
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    Success! Looks good! Are you making them for sure now? Can I play my order later on in the week?
      I'm sure I can come up with something for you ;)
        Some stupid questions:
        Do I need a wideband o2 sensor for this setup, like LC-1?
        If I read the specs right, I can ditch the dist cap in lieu of wasted spark by any ole GM coil driver set?
        I can ditch the AFM for MAP? Just run a vacuum hose to the MS unit, and all my air metering is done for me?
        Would it work for a m30 or would the maps be way off?
          ooo. if i didn't have to pick up a new set of tires i'd be on this!
            Unless you are running a config that was already tuned to your engine or had it dyno tuned you should have a WB, once tuned you could go back to NB but why??
            Correct, this has 3 ignition drivers installed to run wasted spark. There are a few coil setups that you can run for wasted spark, the GMs are a common one and fairly documented.
            Correct this will use the MAP sensor so you can ditch the AFM and add an intake temp sensor.
            I'm sure there are M30 tunes around to get you started and then final tune to yours. :)
            Let me know when your ready ;)
              can you do one pnp for a 325e? is that possible? never seen a MS setup in stock case for a 87E
              Pondering boosted ETA with 524td parts to use as DD torque beast....
                These boards are specifically for a 55pin Motronics connector, I don't know there would be that much interest in an ETA base version unless I heard otherwise...
                You could use a b25i harness as you would probably want the front timing wheel setup anyways and wouldn't need the cold start valve and probably better to use the late ICV??
                  very nice piece! are you making the board yourself?
                  ___________________
                  Mark
                    high quality stuff from this guy. See threads on e30tech, A+.
                      If you look really closely you can make out whodwho e30tech.com
                      www.gecoils.com
                        Guess I missed this thread getting bumped, yes I am having these made up :)
                          I am looking in to doing a MS setup for my friend's 2.5L s14. Do you know if they use 55-pin motronic ECU's? The m3's tend to have more early model stuff, so I assume they don't, but I just don't know. I'd love to have something where we could use the stock harness with not a ton of modifying to be done. Also, from what I gather, s14's don't do too well with MAP, so alpha-n would be the way to go.
                          Is this something you could do?
                            Dont you have to change out the tps? I will definatly be ordering one of these!
                              PM'd.
                              edit: PM'd again, for sure this time.
