Fully Built TurnKey Megasquirt EMS in Motronic 55pin Case
This topic is closed.
    It takes about a week to get one together depending on parts and cores, I am a bit down on cores right now.
    I have it setup to be able to use the stock TPS or you can swap it out for a variable one from an M5x or there was a Nissan one with bracket but they appear to be out of stock - http://www.02again.com/?page_id=30
    I have it setup to receive the O2 signal from the stock O2 connector so you would wire the LC-1 output there. If it is a late model you can also get power and ground there for it as well.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      Sent you a pm man!
        Would this work for a s14 m3 ?
          Originally posted by jaywood View Post
          Sent you a pm man!
          Pm'd back
          Not as a PNP but should be able to modified it in.
            pm'd
              Pm'd you again.
              Thanks for being so helpful ;)
                Very helpful guy! Free bump
                Sent from my Galaxy Nexus using Tapatalk 2
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                  Sent you a pm! Bump :)
                    PM sent!!
                      Your inbox is full otherwise I'd send you a PM >_<
                      Is one able to plug a V3.0 board into this instead of the microsquirt module and do you sell it as just the board (assembled or unassembled)?
                        Sorry just seen that.
                        Yes this will take a v3 board as well, I had seen an email notification from cardomain this morning, thinking that was you? I will reply to it and might be easier.
                          so i have an 87 325is. i feel like the 87 325i ecu i just purchased is now useless after some research. do i need a layer model ecu to fire my megasquirt up to or can u make an early model car run megasquirt on the early ecu?
                          this may be answered somewhere but its confusing as hello to me. i just want to be able to run megasquirt on my early ecu and just deal with its sensors. really wont want to hack shit up to run on a late ecu and then to megasquirt.
                          m20 is plenty. im simply a drifter.
                          build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                            87 325is' do have motronic 1.1
                            Driving:1990 325iS, 2007 335i :devil:
                            past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
                              why does ms have to be so expensive :(
                                Tried to send a PM. Box full. Still doing this? Shoot me a PM.
