I no longer have a use for my M20. This engine has approximately 45k on it. It was built by Metric Mechanic as a one off engine. Specs are as follows.
-E block: Bore 84, Stroke 81
-I head (885)
-I intake
-MM Camshaft: 286/274 duration, with a 11.7 Lift.
-25/23 Valve overlap. Total 48 overlap.
-MM Single 'beehive" spring valve springs (S14/S38 7mm stems used)
-MM Rally Forged Alusil Vented Pistons: 10.8:1 Compression. 330 Pistons 80-90 shaved
-Chromoly piston rings
-MM tuned MarkD' chip
-Ported head, intake, and oil pump.
-140mm Rods (early M50)
-8mm allen Head bolts
-Timing advanced 8 degrees.
Replaced when built:
Rocker arms
Valve guides
Rod Bolts
Rod bearings
Main bearings
Exhaust shields
All gaskets
All hoses
Replaced 20K ago:
Timing Belt
Timing belt tensioner
Water Pump
Fan clutch
Spark plugs
Recently replaced with no miles:
Valve cover gasket
Oil Pan Gasket
Intake manifold Gasket
Front and rear main seals
Rocker shaft plugs
Engine will come with all hoses, complete wiring harness, chipped ECU, A fresh valve adjustment, and fresh paint on the intake and valve cover. A/C, PS, and Alt are not included. If you have any questions, feel free to ask. This engine would make great for track use, as it is currently set up for top end performance. The engine has never been tracked, only daily driven.
Price is $2200 for the complete engine. $2600 shipped. I feel it is fair considering everything included. The MM pistons, which make this engine a non-interference engine, cost $1170 alone. I am willing to ship. Feel free to PM me with any questions.
-I head (885)
-I intake
Rocker arms
Valve guides
Rod Bolts
Rod bearings
Main bearings
Exhaust shields
All gaskets
All hoses
Replaced 20K ago:
Timing Belt
Water Pump
Fan clutch
Spark plugs
Valve cover gasket
Oil Pan Gasket
Rocker shaft plugs
