legit vdo euro cluster and lots of motometer cluster parts
    i went through my box of cluster parts recently to pull out all my extra tachs for justrack on e30tech for his boost gauge project. i decided since i was in there, i would post up the extras that i won't be needing. these items have not been specifically tested for this sale, but worked when pulled from the car. i would like to keep the sales to a 35.00 minimum if possible. the post office and ups are a good ways out of my normal traffic pattern.
    legit vdo euro cluster. not canadian. you can tell by the icons for idiot lights instead of written letters. i have had this for a few years on the shelf, but i tried it when i received it in the mail and everything was fine. the odo gears are in good condition. 27x,xxx kms. crystal in good condition 125.00
    3 later style motometer si boards. they appear to be in good condition with no corrosion/leaks around the batteries 35.00 each
    random fuel/temp gauges. 17.00 each fuel gauge sold
    motometer speedo with new (in 2002) odo gears. there is a sharpie note on the back of the gage with someone's initials dated 2002 and 120,000 miles. the gauge now shows 145,xxx miles. removed from an 88 325ix. missing the needle as i used it for an orange needle project, but you can use the one from your broken gauge. all you have to to is use a kitchen fork to pry the needles off your old gauge and press it on the new one. don't really want to sell this very bad, but for 55.00 i will let it go. SOLD
    really nice motometer bezel. no crystal. for those of you with broken tabs. 15.00 i have several other bezels in various degrees of condition. please inquire
    vdo euro/canadian speedo head with no gauge face or needle. odo gears are in good shape and it works. you will need your km/h gauge face and needle. 35.00 no, this will not work with your mph speedo cluster unless you don't care if the calibration is off by 40% SOLD
    random motometer speedos. no needles and (of course) each one has a bad odo gear or two 15.00 each
    random temp/fuel gauges no needles but they worked when removed from clusters 7.00 each
    cluster crystals. these have small damage at the bottom mostly from being improperly removed from the unit. they have minor scratches but nothing too bad. very usable. 7.00 each
    adapters for adding cruise control. mounts on the back of the cluster just below the speedo 5.00 each
    if there is any other cluster part you are interested in but don't see listed, i probably have it. please inquire. all my extra tachs are sold.
    this one goes in my s52 swap. not for sale ;)
    thank you for looking over my for sale thread. i have shitloads of other parts for sale as well. will be running more ads as i get to it. check my sig. if you see something you might need, let me know
    Gigitty Gigitty!!!!
    I have an early model fuel tank (one sending unit/pump on the passenger side) in my late model e30, (driver's side sending unit connector is unplugged) i jumped the driver's side plug so my gas gauge can work... somewhat. (it stops at 1/2 tank)
    i was wondering if i put a early model fuel gauge in my cluster... would that fix my problem?
    sorry for the threadjack, but im interested if it would work
      I'd like one of the fuel gauges...for a later model (2 tank).
      Thanks,
      Jack
        You seem like you're familiar with the gauges. Do you know if a 7k Motometer tach exists that works with earlier E30's?
        I've got a Motometer cluster with a 5k tach, but I need to swap to a 7k. I ordered one off eBay, but it must have been for a later model because the back was totally different.
        -Brandon
        '86 325es S50
        '12 VW GTI Autobahn DSG
        '03 540i M-Sport (sold)
        '08 Jeep SRT-8 (sold)
        For sale:
        S50 TMS chip for Schricks
          I need the 145,xxx ODO.
          I will send the payment on Sunday night. Is that ok?
          » PARTS FOR SALE
          » TRANSACTION FEEDBACK
            Originally posted by flyboyx View Post
            Can you tell me more about this cluster? I need to find one.
            1989 US E30 Cammed S52
            Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
              Originally posted by achtung View Post
              can you tell me more about this cluster? I need to find one.
              +1
              ( f ; _ ; )f
                  no worries, i am not positive, but i think you need the 86 and earlier style gauge to go with that sending unit. i only have the later style gauges for sale right now. perhaps you can go with a sending unit from a later model car?
                  Thanks,
                  Jack
                  i think you pm'd me yesterday. i will respond to you via pm.
                  also not positive, but i think you will need to find a 7k tach from an 86 and earlier cluster. i think you may need to change the coding plug as well. unfortunately, i only have post 86 parts right now.
                  ok. send me a pm with your zip and i will factor in the shipping
                  it is a vdo m3 cluster with metal/chrome vdo trim rings. someone was selling the rings in germany and i liked them a little better than the brushed rings for sale presently on this forum. i have the original m3 bezel that came with the cluster, but it was missing the "m" sticker in the middle when i received it. i thus switched to a standard e30 vdo bezel.
                  as far as the trim rings are concerned, i have found that the bezel holes in the vdo cluster are a little smaller diameter than motometer. the rings snapped tightly in this cluster without cement, but were sloppy and loose in a motometer.
                  Gigitty Gigitty!!!!
                    thread updated with sold items
                    Gigitty Gigitty!!!!
