I am at work and cannot post pics ATM, but for anyone as impatient as i am when buying stuff, here is a link to the pics: http://forums.bimmerforums.com/forum....php?t=1664712
And really this is the perfect setup for an e30 guy who wants to go 24v turbo... The pan you need is already here, I HAVE the 413 red label ecu AND harness you can use, the works. If anyone wants EVERYTHING I can hook you up pretty well!
Alright... so I am about to finish this car up and ran across a minttttt Z3 M Roadster for the right price.. So I am selling my shit and getting it!
I have pics of everyytthing and will put them up when I get home. I have more FS but I want to get this few things rolling first.. Will add more in a bit
--So we have the s52 out of my 97 m3 automatic with 120k on it. Head was refinished, all valves removed and cleaned, BRAND new valve seals, ARP 2000 head studs and either a .140 MLS HG or the stock HG. I also have both the stock m3 oil pan for e36s and the e34 525i oil pan w/pickup for the 24v e30 and e34 guys. All new gaskets etc. Motor has all accesories and block painted gloss black. I have both the s52 valve cover for it as well.. Also you can have it with an obd1 m50 manifold and manifold conversion or the stock s52 manifold and I could include the stock injectors if you would like as well. $2500, its going together this week with either the stock hg or .140 mls that you would like with whatever oil pan youd like.
$1500 Sounds like I may have a buyer on just the shortblock if anyone wants a freshly machined s52 head with inspected/cleaned valves and new valves seals plus the obvious s52 cams
But the whole block is still currently avaliable.
Head refinished:
Fresh/cleaned deck:
Motor apart/painted:
Cleaned oilpan:
Cams and valve seals being done:
$290 Precision 46mm wastegate
$170 Synapse BOV with weld on flange
Both pictured in boxes:
$800 Next I have my Precision Turbo PT6262 T3 with Vband hotside. 0.82 AR and 4" shroud/intake.
$480T3 Top Mount "OtisFold"
$900 Warchip with blow through MAF, Seimens 60lb injectors, Chip and weld on maf flange.
$200 Treadstone TR10 intercooler (wicked nice aluminum cast end tanks!
Head refinished:
Fresh/cleaned deck:
Cleaned oilpan:
