Current parts list. E30. prices aren't set in stone for most parts. high demand parts obviously will be firmer.
also available at minneapolisbavarian.com
Hoods:
1989 325i Zinnoberröt, faded, paint chipping on front edge $20
1985 325 Zinnoberröt, faded, rust free. $50
1994 325i Bostongrünmetallic. small dents and such but certainly passable. $20
1995 740il: black iL hood, good. $100
fenders:
1992 325iC: Driver's side Alpineweiß II a couple of small dents, no rust though.
1985 325e: Zinno. very nice. RH avail. $60/ea
1995 740il: black. solid, but some surface rust is happening on the bottom edge.
trunk lids:
1985 325E: Zinno, good shape $30
1991 318i: Brilliantrot good, but not great. $20
1995 740il: black, little rust. good latch $20
brakes:(inquire for exact price)
1986 325es: front and rear calipers w/good pads. rotors un available, felt good on test drive.
1987 325e: front and rear calipers w/ok used pads. front rotors warped.
1990 325i: front and rear calipers. front and rear pads good. front rotors=uselessly warped
1992 325iC: front and rear calipers. Front and rear pads good, all rotors there but never drove the car, no idea on condition.
1995 740il: all 4. good pads and rotors.
1985 325e: all 4 brakes, good
1993 325is: all 4 brakes, good
1994 325i: all 4 brakes good.
E30: brand new rears
E30: front drilled and slotted rotors
E30: OEM rear pads (new in box)
E30: rear rotors almost new (100miles)
suspension:
2 sets of rear struts with good top mounts. various brands. KYB, Boge, etc. $30-50
1990 325i: front and rear bars $20/$15
1991 318i: front struts, springs, top mounts. bad struts
1992 325iC: rear struts.
1995 740il: front and rears. dont know on condition, seem fine.
1989 325iC: front strut inserts $40/pr
1994 325i: front and rears, drive well, no idea on miles $100
1985 325e: front and rears non-abs. $100
1994 325i: front knuckles $25/e
1994 325i: rear subframe with trailing arms $100
1993 325iS: front knuckles $25/e
1993 325iS: rear subframe with trailing arms $90
1993 325iS: M3 race camber arms. $200
E46: LH aluminum control arm brand new in box $100
Steering:
1985 325e: steering rack with tie rods. $100
1991 318i: new LH tie rod, out of allignment, leaky boots $80
1995 740il: steering box, good.
E30: brand new MOOG outer tie rod end $email
engine:
1994 325i: M50TU cylinder head $200
1986 325eS: full intake manifold, all sensors, harness and ECU $60
1987 325E: full intake manifold, all sensors, harness and ECU $60
1995 740il: M60B40 engine 200psi +/-10 on all 8 cylinders $300
1993 325iS: M50B25TU great runner 173k $299
1992 325iC: Motronic engine harness $100
accessories:
1987 325e: DENSO a/c compressor forgot to test $30
1990 325i: DENSO a/c compressor forgot to test $30
1992 325iC: SEIKO a/c compressor not tested $30
1990: 325iC: ZF power steering pump. perfect. w/bracket $10
1986 325es: ZF power steering pump. perfect. w/bracket $10
1987 325e: ZF power steering pump. perfect. w/bracket $10
1989 325i: ZF power steering pump. perfect. w/bracket $10
1986: 325es: alternator. perfect. $40
1989 325i: alternator. perfect. $40
1994 325is: alternator $50
1993 325iS: alternator $50
1991 318i: alternator $50
1991 318i: P/S pump $30
1994 325is: P/S pump $30
1993 325iS: P/S pump $30
1994 325i: A/C compressor $40
1994 325is: water pump $10
1993 325iS: water pump $10
1995 325i: water pump $10
1994 325is: trigger wheels, pulleys, etc. $5+
1993 325is: trigger wheel $5
starters:
1990 325iC: 1.4kW. perfect $30
1989 325i: 1.4kW. perfect $30
1987 325e: 1.4kW. perfect $30
1986 325eS: 1.2kW DirectDrive, perfect. $25
1990 325i: 1.4kW. Perfect. $30
1992 325iC: 1.4kW perfect 4 post $30
1993 325iS: starter motor $35
1995 740iL: starter motor $50
1985 325E 1.2kW direct Drive $25
Transmissions:
1995 740il: ZF5HP 5 speed automatic trans. shifts very well, should change the fluid though as it has been a while
1994 325i: Getrag 250 trans. never drove it, 170K miles on it. hand shifts all gears fine. fluid looked fine $80
1987 528e: 30,000 mile mint getrag 260 $180
1991 318i: Getrag 240 $100
clutch/flywheel:
full Getrag 240 5-speed swap from 1991 E30 318i $500
1993 325iS: FW, PP and clutch disc (single mass) $email
1991 318i: FW PP and clutch disc (dual mass) $emai
HVAC:
E36: blower motors $60
E38: blower motor $60
E38: interior HVAC steppers and computer, panel etc. $5 and up
E36: lots of HVAC stuff $5 and up
interior:
1993 325iS: black premium sound door panels $150
1990 325iC: cardinal red rear seat bottom. $40
1989 M3: black leather seats front and rear. near perfect, no rips or tears. $700
1992 325iC: full light grey vert' interior. some refinished in vinyl, looks good. $500
1995 740iL: some interior bits
doors:
1990 325iC: drivers door. white. has glass, mirror, regulator. needs motor. no door panel $100
1990 325iC: passenger door. red. gas glass, mirror, regulator, motor. no door panel. $120
1986 325eS: drivers door: little rust on bottom edge, has regulator, motor, interior handle and mirror. no door panel. $40
1986 325eS: passenger door: no visible rust. no mirror. has motor and regulator.$40
1986 325eS: fuel door. alpineweiß $5
1990 325i: 4 door, all window regulators and motors except passenger rear. $40 per corner.
1992 325iC: drivers door, alpinewhire. dented, but rust free. has a regulator, glass. $100
1992 325iC: passenger door, alpinewhite. perfect, perfect, perfect. $120
1995 740iL: all 4 doors and or parts available. black ext but rusty bottom. tan interior.
1998 M3: Cosmos Black RH door with late model regulator and wiring harness. perfect shape w/glass $100
1990 325iS: silver RH and LH side views $10/e
1994 325iS green LH and RH side views 10/e
1987-1993 E30 325iC: rear windows with regulators $80/ea
Exhaust:
1995 M3: gutted cat-back $70
1995 740iL: full exhaust, minus cats. $email
1993 325iS: mint cat-back $60
other:
1986 325es: check panel $10
1992 325ic: ABS check panel $10
1990 325iC: headlight grilles $10
1986 325Es: kidney grilles $20
1990 325iC: kidney grilles $20
1986 325eS: various radiator hoses, belts.$5/e
1990 325iC: various radiator hoses, belts.$5/e
1987 325e: various radiator hoses, belts.$5/e
all models and years: electrical relays, fuses. a plethora of them. $1/relay $1 a dozen fuses
1990 325iC exterior trim $50
1986 325es: front aluminum bumper $20
1986 325es: front lip spoiler $270
late model (86+) front and rear indicators w/clips $10
86 & 87 exterior moulding trim
ABS computers, relays, sensors $15/ea
1987 325e: tail lights. good cond. left and right. $25/ea
1990 325iC: turn signal stock and uncut harness (for OBC CAR) SOLD
1990 325iC: ignition switch and uncut harness $20
1990 325iC: cruise and wiper stalks with uncut harnesses. $15
1986, 1987 and 1990 325i/e/es/is/ic cruise control servos $5
1990 325ic: brake master cyl w/reservoir A/T $20
1986 325eS: brake master cyl w/reservoir M/T $20
1990 325i:set of 4 bottlecaps. straight but paint is rough and the tires are getting down there. no caps. $100
1990 325i: airbag steering wheel. v/g shape $40
1990 325i: late model tail lights left and right $20/ea
1986 325eS: Manual Transmission pedal cluster $60
1990 325i: master cylinder and reservoir for manual transmission cars
1986 325eS: master cylinder and reservoir for manual transmission cars
1992 325iC: sealed beam headlights good
1992 325iC: late model RH tail, v/g.
1992 325iC: 4.10 differential.
1995 740il: LOTS of stuff. pretty much everything.
cooling:
1984-1993: M20 fan clutch $30
1986 325eS: radiator $60
1985 325e: radiator $60
1988-1999 325 328 M3 radiator: $90
1991 318i: M42 radiator $70
1993 325iS: radiator w/shroud and overflow tank $120
1998 M3: fan clutch with fan nearly new $50
1995 740iL radiator with overflow tank $100
1995 740iL fan clutch with fan. works well $40
ignition:
1986 325eS: ignition coil. Bosch. Good. $20
1987 325e: Ignition coil. Bosch. Good. $20
1985 325E: OEM ignition wires $30
1990 325i: Ignition coil. Bosch. Good. $20
1989 325i: Ignition coil. Bosch. Good. $20
1995 M3: Ignition coils (have lots. Bremi and Bosch) fit most V8 and OBD-1 L6 engines $15/e
1991 318i: ignition coils $100 set
driveline:
1990 325iC: automatic front and rear driveshaft $40 or free with the automatic transmission (x2)
1987 325e: axle shafts. no leaks in the boots. $80 comes with rear control arms and hubs.
1987 325E: trailing arms and axels
1991 318i: trailing arms and axels (for small case) has bad R wheel bearing.
1992 325iC: 4.10 diff (non LSD)
1989 325iC: 4.10 diff (non LSD)
1993 325iS: LSD.. dont know ratio $250
Fuel: (had a lot of DOA issues with these, so they are as described, but As-Is.)
1991 318i: fuel pump plugged in 12v, motor spun up fine, dont have a tank to test it $40
1987 325E: HPFP, side mount. pretty quiet. works great.$80
1987 325is: OEM fuel injectors. one is missing a pintle cap. $10
1994 325i: fuel pump $50
1993 325iS: fuel pump assy. $70
1990 325iC: fuel pump assy $60
vert' specific:
rear windows with regulators and motors. perfect. $80/each
late model vert' TBL. $30
doors ( listed above )
interior electronics:
1986 325eS: VDO gauge cluster, everything works, ~230,000 miles $80
1987 325E: Motometer gauge cluster, everything works ~190,000 miles $90
1992 325iC: ODO/Trip is broken, everything else is working fine. $60
1994 325i: cluster. works I think. 194K $80
1995 740ol: cluster. one bad backlight bulb, all gauges work, all LCDs and Ribbon Cables are good. 217K $200
1993 325iS: perfect clluster $80
1993 325iS: perfect OBC $60
Wheels/Tires
E36 steelies one has a bend in the lip, seats tires fine $40
E34 spare wheel/tire great shape $20
17x7.5 Alpina replica wheels with center caps and Kumho 215/35-17 tires $1000
15" 4x100 mazda steelies from an 02' Protégé $40
15" 1993 325iS wheels and crap tires $80/set
text message 61 22 42 14 31 or email me Erik@minneapolisbavarian.com
NO PAYPAL ACCEPTED I take CC, Amazon payments, Google checkout, MO, etc.
Hoods:
fenders:
trunk lids:
suspension:
Steering:
engine:
accessories:
starters:
Transmissions:
clutch/flywheel:
HVAC:
interior:
doors:
Exhaust:
other:
cooling:
ignition:
driveline:
vert' specific:
Wheels/Tires
