FS: 18x10s For E30s
  • jajou318
    • Jan 2005
    • 1023
    Originally posted by Bavarian3
    I saw your spacers and believe me; I wouldn't run them...... maybe they are fine for now but what about the stress on the hub?
    Heh, I mentioned that on BF.c but they are idiots and wow ignore what i say ok.
    One thing it is adapters...no go on that.
    2nd thing spacers are ok but with adapters i dunno....
    Good luck with the sale... :|
    • E30 Racer
      • Nov 2004
      • 427
      I'm going to take a gander and question the use of 18x10 and 285s tires....
      Of course the width of the wheel/tire will stress the hub more, you're generating waaaaay more grip that possible with 225s, etc.
      "The highest placing E30 at nationals this year was running 285s on 18x10s..." I'm looking at results from SCCA and can't seem to find that information...
      Check the DSP results at:
      You think if a buyer who wants to put those adapters on his/her E30, will automatically be a fast(er) car?
      That's the idea. :up:
      Garrick
      1989 325is
      DSP #72
      • Bavarian3
        • 1230
        "Of course the width of the wheel/tire will stress the hub more, you're generating waaaaay more grip that possible with 225s, etc. "
        Hmph.... It might just be me who thinks this but my comment was directed at the adapters on the hub, not the extra grip from the 285s.... plus the fact of the extra rotation mass, 50lbs per wheel, gearing changes...
        I understand that Alex wanted to run 285s, at which I too questioned why...
        Good luck with your sale though..
        • alex
          • 2024
          18x10s are heavy, expensive, and they don't even look good on E30.
          They will make you want to hack up your fenders.
          They will slow you down so that you can't even beat a lowly E36 325is with 2.8 swap, JRZ shocks backed up by a long time reputable BMW tuner shop with multi time National Champion driving.
          They will make your car pick up inside front wheel in turns and sometimes they will even make your car pick up both of the inside wheels and scare the hell out of corner workers.
          Don't bother with these cheap used 18x10.
          IMHO custom made 18x11 at $600+ each would be the way to go. ;)
          • Bavarian3
            • 1230
            Yeah but Alex you don't want the car to lift any side of the tire, correct?
            Maybe my comments are just out of placed...
            • alex
              • 2024
              It was more of a joke than not. Sorry if it came across otherwise.
              Honestly, I don't know if that's an advantage or not. Theoretically, if the tire stays on the ground if provides grip and while it is in the air it definitely does not provide any grip.
              Practically, even the E36 that I mentioned above was lifting it's tires. Also if you watch some of the old DTM videos and you can see all kinds of air under the tires.
              I'd say that if you try to go fast sometimes you have to accept the fact that at some point it'll come up regardless of whether it is good or bad. You can try to get rid of lifting fron tinside tire but stiffening the rear spring rate or the rear sway bar, but that will in theory increase oversteer or decrease rear traction.
              The point I was trying to make was that Garrick's setup is moderately low budget for someone wanting to run 285/18 tires on their car.
              • Bavarian3
                • 1230
                Alex,
                I too didn't mean it in a negative way, I had my wisdom teeth removed yesterday morning so I was on some percocets... :)
                • E30 Racer
                  • Nov 2004
                  • 427
                  Price reduced. $1000 for the wheels/spacers/lug nuts. $150 more if you want to keep the set of 285/30-18 Hoosier A3S04s presently mounted on the wheels. If interested, please email me at der325racer-e30@yahoo.com
                  Start your winter project now!
                  Garrick
                  1989 325is
                  DSP #72
                  • E30 Racer
                    • Nov 2004
                    • 427
                    Originally posted by Brew
                    What is the weight of the wheel + adapter per corner?
                    The wheel weights about 34 lbs. I've never weighted the spacer by itself, but figure about 5 lbs. Keep in mind that an expensive 18x10 (i.e., Fiske, HRE, etc.) all weigh about 21 lbs and cost megabucks....
                    Garrick
                    1989 325is
                    DSP #72
                    • Brew
                      • 3060
                      My bad, I missed your post earlier mentioning that.
                      Good luck with the sale, I'm sure someone will pick them up. I really would buy them if they weren't so heavy...
                      '91 318is
                      • E30 Racer
                        • Nov 2004
                        • 427
                        Bump.
                        Garrick
                        1989 325is
                        DSP #72
                        • E30 Racer
                          • Nov 2004
                          • 427
                          Final price before everything gets split up and sold on eBay this weekend: $950 including tires. Guys, this is a steal. :up:
                          Garrick
                          1989 325is
                          DSP #72
