FS: 95% of the power lock/power window system...wires, motors, etc
  • irish44j
    • 2763
    So since I have no need for any of it, I pulled the entire power accessories system from the e30 (which is getting a full gutted interior).
    Asking $150 shipped or ANY reasonable offers for ALL of the following:
    - 95% of the wiring. I tried to get it out as cleanly as possible, but did have to cut off one or two of the door harnesses to remove them. Basically it will include all of the wiring you need and all of the associated connectors that I could get out. It'll be missing a few minor sections, but overall the harness is mostly complete and won't be hard to fill in the missing areas. No shorts or anything that I"m aware of.
    - 4 window motors: The two rear door motors worked perfectly when I removed them. The driver's door motor worked intermittently, i think one of the switch wires was loose. The passenger front motor didn't work, but it might have been a bad connection. I didn't check too hard since I wasn't going to use it.
    - Motor rails/tracks if you want them. Otherwise I can just take the motors off. These are from an earl model, so they're the "S" shaped track, not the straight lifter on later models.
    - 5 lock actuators - all 4 doors plus the trunk actuator. No idea if any of them work. the main box wasn't hooked up, so never tried to test them. They don't appear to be damaged or anything.
    - The central locking module. Again, no idea if it works or not, but appears fine from the outside.
    - 5 or 6 window switches. At least 4 of them work, not sure about the other two.
    - All the pigtails that were attached. I think there are 3 or 4 larger ones total.
    Also included is some other random wiring (for some of the interior lighting), as well as the interior lighting timer module (attached to the same bracket as the main lock module.
    so...that's about it. I'm trying to represent what I have as accurately as possible. It's not gonna be all plug-and-play, but most of it is there and in decent shape.
    whatever, make an offer, I could sell parts individually (like all the lock modules, or all the window motors) if you want. Would rather just sell the whole box 'o stuff.
    here's a pic of the box of stuff. If you want pics of the stuff all sorted out I can do that...
    Stage rally/rallycross e30 build/competition journal
    Track/street e21 build
    visit Condor Speed Shop
    visit Motorsport Hardware
    [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
