This. Thanks hammered fo rthe info, but lets go a little further, is there an option for the end user to adjust (lets say i want boost, AFR, and oil temp today) but tomorrow I want AFR, volt, and coolant temp, is it a matter of switching plugs to sensors that could be preinstalled? Or can you cycle options on the device. Can I change the configuration myself?
They are ready...
I think he more than just works there. MC Hammered is a local guy, and a far as I know he is the founder and designer of Podi and their products.1990 332i, 4 door
2008 KTM 990 Superduke
2018 Golf R, 6spd manual (Pending delivery)
2017 Mazda CX-5 GT
2007 Z4M Coupe - Sold to very nice peopleComment
I take it you work for the company who made it? :)
Thank you for clearing up exactly WHAT they can do! Now I know I have to have one of these, period. Question, what needs to be done to make the gauge function with the readings I want? Is it something I can do or does it need to be set from the factory? If I am running the Innovate LC1, how will it hook up to this?
Thanks, and GPS rocks.
To hook up the LC-1 you just run the wideband output from it (brown wire) to the corresponding input on the terminal block, program the gauge 0V and 5V endpoints to match the LC-1 output and the gauge does the rest.
The displays on the gauges themselves are fixed, so what you see is what you get, but you can swap out the gauges for different ones that show different readings. You would require the appropriate sender to supply the new signal as well.
So for your particular setup lets says you were running the following:
left gauge: boost, AFR
right: oil temp, coolant temp
now you wanted to wanted to read voltage, you would do the following:
pull the gauge out
disconnect all the input wires
pop the back cover off
remove the oil temp, coolant temp module
install the voltmeter module
install back cover
connect all the input wires to the correct sensors
done!
now you have the following
right: voltmeter (with bargraph)Last edited by MC Hammered; 01-05-2012, 12:57 PM.
My 1989 e30 s52 Touring... this is Betty
My 1989 325i vert (sold)...this is Nina
My 1991 M5 (sold)... this is Veronica
Photo comparison: OEM vs aftermarket windscreen for a convertibleComment
For the person that asked earlier - no the E34 vents aren't exactly the same. :(
I've been watching Winston create this little beauty; congrats on bringing it to market, and thanks to GPS to selling it to the community!Comment
I am still bot fully grasping it. If I want the gauges to give a different reading than the factory setting do I change out the physical gauge or is it programmed in somehow? If programmed to read differently, how is this done?Comment
A boost and AFR gauge combination will only ever show boost and AFR readings.
Just like a multi bit screwdriver, you change the bit to make it work with the screw.
I do not believe many people will take advantage of this modular design and having up to 4 readings should cover the needs of 95% of the users out there.
In my built Audi I ran boost & AFR, oil temp & oil pressure as those were the 4 items I was most interested in keeping an eye on and never changed them.
For the remaining 5% that have some crazy build, they will already know exactly what parameters they want, would know when they would need to change out displays and if they choose to use both air vents they could monitor up to 8 parameters at once.
Thanks for the answers, sorry for the questions!
One final question, is there an additional charge to order a custom combination of gauges?
Thanks!Comment
this is an awesome product. Can't say I have really wanted anything new for a car for a long time but this changes everything.Comment
For pricing on a custom setup I will have to forward you to Levent for that. :up:
I'll contact L, thank you sir.Comment
For those of you interested in the Valentine 1 remote display function here is a video of how it works.
The PVG-e30 module would work exactly the same way except you use the remote switch to program and silence the unit
