M42 Engine & Performance Parts
  • rob_e30
    • 456
    Everything below comes out of my garage or our race trailer. These are spares or parts for future projects that we won’t be using. Many are new or like new, most are cleaned, some need to be taken apart for components and cleaned. All sales are As-Is, local pickup preferred but we might ship at buyers expense. Some of the larger, heavier parts will be expensive to ship. Nothing comes with a warranty, guarantee, or promise of completeness or suitability for any specific application. Please contact before purchasing if you have any questions.
    Front Timing Case Seal NIB $10
    E36 M42 Wire Harness - $125 Includes relays
    M42 Intake Plenum (Upper half only) – Half Price! $25 plus shipping
    M42 Dampner, Crank Pulleys - $30
    Idle Air Control Valve (1 available) $50 each
    Power Steering Pump (Dirty) $80
    Cam trays and buckets (2 complete sets) $25 per set
    Head for spare parts. #3 piston dome destroyed. CAM trays, springs, and remaining valves are good. $50
    Polished valve cover, could use new polish but should clean up nicely. $80
    M42 High performance short block. Engine was running when disassembled. Intended for high rev, normally aspirated street/HPDE application. Knife edged/lightened crank, custom rods. Believe to be $1.8+L motor based on our bore and stoke measurements. There also a photo of a crank for reference purposes. This bottom end is assembled and ready to go. Includes new water pipe. $500
    Fan, water pump, thermostat and pulley. Came off the High Performance engine. Steel impeller water pump. $50
    Painted upper and lower timing case cover and thermostat housing. Came off the High Performance short block engine. $100
    Inner timing case with crank bolt and hall effect crank position sensor. Came off the High Performance short block engine. This is an aftermarket dampner, with the sensor (vendor not known). Uncertain if the timing case was modified to fit only this sensor or if a stock sensor will still fit. This is a great upgrade if running an aftermarket ECU. $250
    Black Powder Coated Intake and Valve Cover Kit. Includes custom intake adapter for an M20 throttle body. If you don’t want the adapter, let us know and we may separate but they were bolted together when we took the picture. All were professionally crinkle powder coated, but the valve cover would benefit from touch up with black engine spray paint. $125
    Alternator, bracket, and dip stick tube. $150.
    Oil Cap & Oil Filter Housing - $80
    lower pan has been welded. $75
    Lower inner and outer timing case and cover. Also rear main seal cover and thermostat housing. $100. Note, the inner timing case needs to be cleaned, still has part of the old water pump that needs to be removed. Willing to break this set up.
    Left and right motor mount arms $75
    Left motor mount arm only (dirty) $40
    Timing components –Cam sprockets, timing chain guide, timing chain tensioner – All in excellent condition out of a motor that was just rebuilt. $125
  • rob_e30
    • 456
    complete head and flywheel pending sale
    • Tismael711
      • 791
      u have a PM
      • rob_e30
        • 456
        Replied!
        • jrobie79
          • Mar 2006
          • 2526
          I'll take timing chain tensioner....paypal?
          1991 318i ---- 308K - retired
          • rob_e30
            • 456
            New water pump kit and chain tensioner sold!
            • rob_e30
              • 456
              Header sold
              • rob_e30
                • 456
                One of the upper oil pans is sold. The other complete set and a welded lower pan are available.
                Don't be afraid to make an offer, especially if you're looking for more than one part.
                • Ludvig02
                  • 36
                  PM'd
                  • Son_of_Man
                    • Aug 2011
                    • 127
                    Why no monies when all the good stuff goes for sale? The bottom end is gold to me! trade fOr left nut or semi used girlfriend?
                    Sometimes better...Isnt really better.
                    • rob_e30
                      • 456
                      Please post a pic of the girlfriend.
                      • Son_of_Man
                        • Aug 2011
                        • 127
                        Pics as requested....
                        She alright
                        Free bump i really wish i could grab it off you but money doesnt allow right now. Glws
                        John
                        • nokincy
                          • Feb 2012
                          • 302
                          Shipping on valve cover to 38201?
                          • nerdydorkus
                            • Feb 2012
                            • 132
                            Hello, I'd like to purchase the complete m42 head, email me at Andrew.luu@cox.net for the fastest response
                            Thanks!
                            • rob_e30
                              • 456
                              The complete head is sold, if you want the damaged head I still have that one.
