Hey guys, running a bit short on cash at a really shitty time to do so (my transmission died in my car last night).
MORE PICTURES HERE
All prices are without shipping, if you buy multiple items or larger items I'll work with you to split 50% shipping costs. Shipping form 33428 zip code, US and Canada only please and thanks guys (message me if you aren't from these great countries, and from some far-off land, I'm not against it I just don't want to be surprise shipping to Australia again like I've had happen....)
Parts List:
*Sealed Beam Headlights in minty-clean shape, include connectors with ~3inches of wire to splice left on each of the connectors. $40
*UHMV Solid 24V Swap motor mounts (used twice on the street, never tracked, my 24v swap never saw the day of light except those 2 drives). These are $100/set new, so I'll say $60/set for these ones just to get some cashola in my pocket. SOLD
*Stock 24V swap mounts, never used $40 SOLD
*M42 AFM + airbox + filter (old), 127k miles old. $40
*Magnaflow 2.5inch dual in/out X-pipe never used $20 SOLD
*Getrag 240 transmission brace $20
*M42 Headers, 127k mi old $40
*M42 Timing case cover $10
*S50 Clutch fan all fins in perfect shape $10
*M42 Cams and cam carriers $40
*M42 Timing chain gears $20 SOLD
*M42 upper timing chain guide $10
*M42 Thermostat Housing $10
*M42 Ignition Wires 127k mi old $30
*G260-24V swap transmission brace made by White325iS on here, sold for $100 new, $75 shipped SOLD gets it to your door.
*M42 ECU bracket $20
*Drag DR-31 16x7 ET40 4x100 rims Hankook Z214 C50 compound DOT-R tires in 205/50/16 size. SOLD! You WILL need spacers to run these rims (15mm front, 20mm rear, can be bought from ECS Tuning or otherwise).
I'd like $300 for the rims, tires were sold locally to a friend. Shipping will be between $90-$150 for the rims in the continental U.S.
*BBS RF320 16x7 ET42 4x100 rims (machined 54.1mm centerbore to 57.1mm to fit the E30's hub) + 2k mile old Kumho KU-36 Summer Tires. Set of 5 rims, only 4 have tires, all 5 are machined to fit the E30 hubs though. Would include a set of ECS Tuning hubcentric spacers + extended lug bolts + caps + original BBS lug-nuts (can't use since E30's have bolts not lugs). Spacers are 15mm front and 20mm rear, and require zero fender rolling, no fender pulling, and there is no rubbing anywhere using this setup, yet it gets as close to flush with the fender as possible. I'm over $1750 into the wheel-tire combo, but I'd take $1200 + shipping for the set as-is. They're dirty in the pictures but if you browse my other photobucket albums you'll find clean pictures.
Any questions you can contact me via PM here, email at rwentroble at gmail dot com, or if you want to buy things without questioning (since what you see is what you get here...) my paypal is the same as my email, at rwentroble at gmail dot com.
Shipping on any item, except wheels and tires, shouldn't exceed $20 shipped to the opposite coast, unless it's a larger item in which case I'll disassemble it if possible or we'll split costs like I mentioned before.
I'm willing to work on prices, so don't be afraid to tell me that anything I have listed is out of line, but don't try and lowball me either please and thank you!
Happy shopping r3v'ers!
MORE PICTURES HERE
Parts List:
