FS: Cooling Mist N/A Water Injection kit.
  • Jordan
    • 12908
    100PSI N/A Single Stage kit as purchased from Cooling Mist.
    Retail is ~215.
    I will sell it shipped for 1/2 of their current sale price, $100.
    Everything in the kit functions perfectly and quite to my satisfaction, just won't have much use with it with my next set of modifications going on shortly.
    https://mtechniqueabs.com/
    • 37828
    I just cleaned up this thread, any more off topic replies may result in timeout, keep it on the subject at hand
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • var1ant
      • Apr 2005
      • 509
      Could you explain to me what exactly this kit does? I'm curious.
      '87 alpine white 325is
      • bwanac
        • 3354
        Yah... WTF?
        • Ravins
          • Aug 2005
          • 128
          PM Sent
          Sold-87 325
          BBS RK Wheels
          H&R Cup Kit
          E30 ///M3 Light up knob
          Clutch Stop
          ///M Roadster FloorMats
          Jim C Chip
          91 318is
          M50 Swap
          Headers
          UUC Underdrive pulleys
          K&N 3in Cone
          Jim C Chip
          Soon H&R Coilovers
          BBS RS
          • PeaveyBassist
            • Sep 2004
            • 3511
            It injects water into the cylinders in a mist. Usually used on high power engines where the cylinders get extremely hot. To keep temps down they use water injection. It basically mists water into the intake and the water cools down the cylinders. Since it injects a very small controlled amount it wont hydrolock the engine. Make sense?
            Will
            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
            Welcome e30 (brilliantrot '90 325is) 12/23/06
            DaveCN = Old Man
            My signature picture was taken by ME! Not by anyone else!
            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
            • e30evolution
              West Werks
              • 1888
              usually high compression where you have problems with detonation from either too high of pressures, temperature... or usually both combined
              http://www.westwerksauto.com
              • Jordan
                • 12908
                Ding ding ding.
                The system injects water as a fog like mist into the intake, where it evaporates. Water has the highest latent heat of evaporization of any liquid on earth. To put it simply water absorbs alot of energy (heat) when it goes from a liquid to a gas. It significantly cools the intake charge.
                • mark1
                  • Oct 2005
                  • 93
                  If you have to ask what it is it's not for you.
                  • var1ant
                    • Apr 2005
                    • 509
                    Hello there mr. high and mighty. I'm glad you could have contributed to this thread.
                    • uflnuceng
                      • Apr 2005
                      • 1049
                      Any idea what the difference in octane you could use vs your compression, or is this more of a preventative measure for high load situations. i.e. could you bump your compression from say 10.5 to 11.5 or 12.0 CR and still stay on 93/94 octane pump gas? What HP are the injectors sized to?
                      Thanks
                      • Jordan
                        • 12908
                        Water injection won't allow the use of a lower octane fuel. It can allow higher compression for that given octane however within reason. I can't say as to how much as I just dont know.
                        This worked to curb my pinging problem (with the added Texas heat) under normal conditions.
                        This kit is good for ~300hp. Different injectors for higher power are available from cooling mist for pretty cheap, as are alot of other upgrade parts.
                        • Jordan
                          • 12908
                          Several interested parties, but no money has changed hands as of yet.
                          bump!
                          • permit
                            • Mar 2005
                            • 3363
                            Jordan, it fixed your pinging and now you're selling? Are you looking at a different engine, or am I missing something here?
                            • Jordan
                              • 12908
                              I have a new head going on with a heavy port + polish, completely reshaped and contoured combustion chambers to promote a proper flame front and full burn. No sharp lines or edges, and significantly increased chamber volume. Chambers also fully mirror polished. Doing ceramic coated headers as well.
                              back to the topic at hand.
