is any of this stuff compatible with IX? i know cabs are, but what about the other stuff? id be in immediately for some of that.
FS: Solid Centered & Offset Front Control Arm Bushings
I've got a set of the solid CAB's and am trying to get them onto a new set of control arms. I can't seem to get the lollipops onto the arms for the life of me.
Is it best to have the lollipops pressed onto the arms, or does dish soap usually do the job? I tried the soap method to no avail. Thanks for any help!
Oh and they shipped right away. Condor has been great to deal with!
About your question, If the Control arm bushings are already perssed into the lolipops, and you are trying to get them on to the control arm, the best way to do it is with a block of wood and a rubber mallet. A few solid hits and it will slide right in.
•• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
•• Rear Subframe Bushings • RTABs • Facebook ••
Im pretty sure the subframe bushings on an IX are different. It seems the subframe is lower on an IX. You may be able to flip our 12 mm Riser Bushings and install them upside down, but I have never done this, so i cannot confirm if it will work.
Thanks! We try to ship as soon as parts are ordered :)
About your question, If the Control arm bushings are already perssed into the lolipops, and you are trying to get them on to the control arm, the best way to do it is with a block of wood and a rubber mallet. A few solid hits and it will slide right in.Comment
Guys, if you have any questions send an email to condorspeedshop@gmail.com
Let me know if you need any offset cabs.
Check the site for pricing.http://www.condorspeedshop.com
Super easy to install.
