All parts are brand new, never installed, unless noted otherwise. I can provide pictures and part numbers upon request. Please only inquire if you are sure that you want to buy. Thanks!
Prices will be posted shortly.
2 - M20 oil pan gaskets /$5 ea.
2 - M20 valve cover gaskets /$5 ea.
1 - Set of coolant hoses (one hose missing from full set) for early M20 e30 /$50 with clamps
6 - oem "i" exhaust valves (stems are +1 oversized they are in original packages with "stuck" stickers) /$100
1 - set of USED M20 "i" double valve springs /$20
2 - rubber M20 engine mounts for e30 /$8 ea.
2 - rubber transmission mounts for 5spd M20 e30 /$10 ea.
1 - timing belt cover rubber gasket thingy /$15
I actually have no idea what these cost. My ignorance is probably your gain. If you have done a timing belt job, you know what this is. It's a thick rubber piece.
1 - USED M20 wiring harness from a late model car /$50
1 - intermediate shaft bearing /$2
1 - power steering belt (contitech) /$8
1 - FAG rear wheel bearing /$30
1 - set exhaust heat shields SOLD
1 - oil feed tube that floats in the cylinder head over the cam /$5
Various plastic bits for sport seats SOLD
Plastic piece that clips into early model knee bolsters. It has holes like a speaker cover or something. I forget what it actually covers. /$5
1 - USED M20 harmonic balancer /$15
1 - air conditioning bracket /$15
1 - M20 rear main seal housing /$15
As you can see, these parts are sitting on the side of the road somewhere deep in the bowels of Brooklyn. Please save them from the shopping cart scrap dude.
