Triple Threat NY TREX nitrous kit
  • Supadave
    • 1006
    I'm selling my NY Trex nitrous kit.
    Price $500 obo
    Kit Retails for over a $1000.
    SKU: 110025
    Ny-Trex is proud to introduce the next phase of nitrous innovation, the Triple-Threat™ wet nitrous system. This system combines all three valve functions: Purge, N20 and fuel in one easy to install component. The Triple-Threat™ is a precision machined billet body with three integral solenoid valves with Volt-Trap coils for a dependable, clean, all-in-one nitrous system.
    Ny-Trex nitrous systems use only the highest quality materials and components to produce the best looking, best performing and most reliable wet system around. Ny-Trex exclusive Triple-Threat™ systems have been thoroughly dyno-tested on numerous vehicles to ensure the most safe and reliable performance possible.
    Complete Systems Include:
    • 10 lb Wet-Black powder coated bottle
    • Liquid Filled Bottle Gauge
    • Fuel Pressure Safety Switch
    • Complete Purge System with V-Spray
    • Chrome 660 Hi-Flo valve with gauge port
    • Braided stainless N2O feed line w/Teflon core
    • 22”x-3 braided stainless nozzle lines, 1 blue, 1 red
    • T-Rex Nozzle & adapter (up to 300+HP)
    • Adjustable HP jetting
    • 15A WOT micro switch
    • Quick-Clamp stainless bottle brackets
    • Mounting hardware, brackets, bolts, screws, clamps, ties
    • Electrical components, wire connectors, relays, switches
    • Drill & tap, fittings, sealant
    • Triple-Threat™ Valve w/Lifetime Warranty
    Special Features
    • Exclusive T-Rex Nozzle with true-blend spray bowl delivers a swirl cone plume at a 110o angle to center the throttle body for an even blend. Flows up to 300+HP yet works great delivering as low as 35 HP.
    • Solenoid valves are made with Volt-Trap coils for stronger, more effi cient power, allows for larger orifice, more flow and works with as low as 9 volts.
    • Plungers are made of high grade alloy with greater
      tolerances to prevent sticking. The N2O seal is Teflon and a special Viton seal is used for fuel.
    • Dual Taper Jets provide a consistent flow of nitrous and fuel and come in a large array of sizes.
    • Easy install components such as well nuts to install bottle topside, drill bit and tap for fuel connection,
    https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
  • Supadave
    • 1006
    Bump
    • Supadave
      • 1006
      New price $450 and I'll throw in a second bottle
