M6X V8 Mounts for E30 / Also 6 sets of blank MMP Turbo Adapters
  • MonkeyMadness
    • 3251
    M6X Swap Mounts
    BUY MY MOUNTS :hitler:
    $80 + shipping
    I also Have 6 blank sets of MMP turbo manifold adaptors
    $80 + shipping!
    Once there gone there gone~!
  • MonkeyMadness
    • 3251
    Bump!
    • Mr. Burns
      • Aug 2011
      • 3516
      wow where were these a couple years ago when I ordered mine from e30.de Germania, pushing $300.
      good deal here kids!
      Originally posted by flyboyx
      i have watched my dog lick himself off a few times
      • MonkeyMadness
        • 3251
        TTT :up:
        • 328ijunkie
          • May 2007
          • 3961
          Are these used with subframe spacers? Any mounted pictures?
          Check Us out on Facebook
          Full Product Line Tuning
          • noid
            • 1529
            Also interested to know if these mounts are based on the idea of using subframe spacers.
            Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
            Your resource to tools and tips: www.rtstools.com
            • MonkeyMadness
              • 3251
              Hello,
              Yes there Pos. 2 and 3
              As all projects there will be some fab work needed..
              They can be used with or without sub-frame spacers!
              These with e34 mount will bolt directly to the sub-frame and clear the pan..
              • noid
                • 1529
                I should rephrase: do these mounts allow for the engine to sit in such a way that drivetrain angle is eliminated or does it require subframe spacers to mitigate the angle?
                If these are a direct copies of the 300mm.de then these require subframe spacers.
                The point is not to clear the oil pan, the point is to have a straight drive train.
                It has long been the norm to use subframe spacers while preforming the m60 / m62 v8 swap into an e30. Where did this norm start? Well basically as far as I can tell it started with an old-er swap guide which you will find somewhat translated here. So for the sake of convenience people
                • MonkeyMadness
                  • 3251
                  Ohhh ok sorry for not catching what you meant... ;)
                  No
                  Yes
                  There will be more on this in my V8 build thread...
                  • 328ijunkie
                    • May 2007
                    • 3961
                    Lame :(
                    • MonkeyMadness
                      • 3251
                      Originally posted by 328ijunkie
                      Lame :(
                      Are you looking to do not use frame spacers with your build?
                      • 328ijunkie
                        • May 2007
                        • 3961
                        Nope. Dont like Fng with suspension geometry. Will be making custom mounts i suppose and modding the oil pan. :(
                        • nrubenstein
                          • 3148
                          Subframe spacers are a shit solution. It has the handling impact of lowering the front end nearly an inch. Given that most of these cars start out low, they really can't afford the loss. 20mm once you're in the bad part of the curve is huge.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • M-technik-3
                            • 18946
                            Should put these in retail.
                            • irrelevante30
                              • Apr 2013
                              • 100
                              are these still available?
