I've got some parts laying around that I'm not using and might do you some good! So I figured I'd put them up for sale for you... Also, I'll be adding parts as I come across them.
Good old fashioned US spec sealed beam headlights. All bulbs in working order!
$50 - Shipped!
Extra passenger side headlight unit with the low beam separate from the bucket (adjusters got bent somewhere along the way). New set of adjusters, and you should be golden! Bulbs in unknown condition.
$20 - Shipped!
Next, a set of US spec front grills. Nothing special here, but if you need one or two, here they are!
$20 each - shipped!
Here is an item loved by some and despised by others! A cup holder in an E30? Yes, you too can enjoy the benefits of not spilling drinks on your concourse-quality carpet! Slides in between the center console and the passenger seat. I've also seen some installations where they screw it to the center console so it doesn't try to slide into the back seat when the epic power of your M50 kicks in!
$20 - Shipped!
Headlight switch and face plate (sold)! And metal gas cap! What more can be said?
Headlight switch - SOLD!
Gas cap $10 - Shipped!
Guibo is gone (sorry)! Also, a pair of Ireland Engineering non-M3 front sway bar links. These things are actually pretty neat little pieces! They are adjustable, so you can remove any pre-load from your front sway bar!
Guibo - SOLD!
Sway bar links $40 - Shipped! - SALE PENDING
Interior ventilation blower motor from a 1991 318is. There are two styles of these, so make sure this is the one you want! Brushes need replacement, but those can be found at places like eBay. (No connection to this seller.) Bushings were a little squeaky, but if you oil those up, they should be good for a season or two... Up to you, but with a little work, this unit could be yours for significantly less than a new unit! Also, one of the cages was cracked, and repaired with a wire at some point.
$50 - Shipped!
Two dark green mirrors with pretty good condition housings! Glass is not so great, as one is busted and one is kinda scratched.
$50 - Shipped!
Front ash tray surround and passenger side trim piece with chrome! Ash tray surround has a red LED installed on the driver's side. Probably originally for an alarm system, but you can wire it to whatever you want! Whether it be a "Go, Baby, Go!" button or a low voltage warning, the choice is yours!
Ash tray surround $20 - Shipped!
Trim piece $15 - Shipped!
Some small fiddly bits I found! The power steering reservoir cap is new - never been installed! Radio fader switch is out of a 1988 M3, so you can install a very covert, but very real, M part in your 325e! Don't have a radio in your track rat? Hook it up to the full carbon wing so you can have maximum downforce in the corners, and maximum speed in the straights! Lastly, there is also a cigarette lighter that is in good overall condition except that all the paint is worn off the top.
PS reservoir cap $15 - Shipped!
Fader switch $10 - Shipped!
Cigarette lighter $10 - Shipped!
Forward center console from a 325ix! This is one of the tall ones from a manual transmission vehicle. Overall condition is very good!
$50 - Shipped!
Forward center console from a 318is! This is one of the short ones, but has the automatic transmission eyelets in the shifter hole. These are easily removed if you have a manual transmission! Overall condition is just OK, as there are some blemishes on the surface.
$40 - Shipped!
And remember! More parts to come... PM me for quickest response, but I will try to check this thread at least once a day as well.
Note on shipping: shipping is applicable to the 48 contiguous states in the United States. If you live elsewhere, pm me, and I'll get you a quote. If you live in Colorado and pick up the parts in person, I will give you a %20 discount!
$50 - Shipped!
$20 - Shipped!
$20 each - shipped!
$20 - Shipped!
Guibo - SOLD!
$50 - Shipped!
$50 - Shipped!
$50 - Shipped!
$40 - Shipped!
