I guess the mods closed my earlier thread listing the CL link.....didn't know that was a "no no". So here goes again.
Selling my S50 engine that I was gonna use for an E30 swap. Engine ran fine when it was removed from a 1995 M3 with 178,000 miles on it. Plans have changed and I am going in a different direction with a different car. Engine was torn down and just about all seals and gaskets have been replaced. I know it got oil filter housing gasket and timing cover gaskets and front crank seal. Head was removed and sent off to machine shop to be checked and sonic cleaned. Of course it got a new head gasket and ARP bolts. Got a new water pump as well. Includes the correct oil pan/pick-up/dip stick for an E30 swap. New timing chain guides and timing chain tensioner. New thermostat and upgraded thermostat housing. New knock sensors. Includes the factory OBD1 intake manifold and throttle body. I also have big bore throttle body, adapter plate and MAF available for an additional $300. I also have an engine wiring harness and a red label 413 DME. Alternator included. New belts. New plugs.
Here is a list of swap stuff I have with individual pricing. I am open to fair offers and will work with you on a package deal.
S50 motor $1500
96-99 M3 trans $300
E34 oil pan/pick-up/dipstick &tube $150
OBD1 engine wiring harness $100 SOLD
413 red label DME $100 SOLD
new/rebuilt (modified) E21 brake booster $300 SOLD
3.46 LSD differential $350
3.64 LSD differential $200
BBTB/3.5" MAF/adapter plate $300
new fan blade $40
new fan clutch $80
new expansion tank $90
new exp tank cap $15
6 cylinder coding plug $25 *needed if E30 is a 318i/is SOLD
motor mount arms $100 SOLD
new E34 535 motor mounts (green ones) $60 SOLD
transmission bracket $50 SOLD
new E21 transmission mounts $100 SOLD
new throttle cable $40 SOLD
new Treehouse eyeball arms $175 *needed due to exhaust clearance issues SOLD
96-99 E36 M3 driveshaft $300
Ebay headers $150 *collector flanges cut off
5-LUG STUFF
used 318ti rear trailing arms/hubs/brake calipers/rotors $300 *will need new brake lines
used '96-'99 E36 M3 front spindles/hubs/control arms/brake calipers/rotors $300 *will need new brake lines SALE PENDING
used '96-'99 E36 M3 rear brake calipers $150 *I have a brake caliper adapter template for the 318ti hubs....if you want to go this route
S50 motor $1500
96-99 M3 trans $300
new fan blade $40
new fan clutch $80
5-LUG STUFF
