Recently pulled a very nice M20 with 5spd transmission from an 89 325i that is getting a S50 swap.
5spd Swap Includes:
- Getrag 260 (shifts smooth, no noise)
- Stock Shifter, Linkage w/ clips and hardware
- 5spd Drive Shaft (good center bearing and ujoints)
- 5spd Pedal Set
- Single Mass Flywheel
- Used Clutch
- Used Pressure Plate
- Used Throw Out Bearing
- Used Clutch Slave Cylinder
- New Clutch Slave soft line
- Manual Brake Fluid Reservoir
- Rubber shift boot (seals the tunnel hole)
- Reverse Switch Wire Harness
- Interior Shift Boot
- Standard black BMW 5spd shift knob.
Does not include:
- Clutch Master Cylinder (had to keep this in the project car)
- Clutch Master Cylinder Hard Line (also had to keep this for the swap car)
I can include the flywheel and pressure plate hardware but honestly, you should purchase that new as its not meant to be reused.
Asking $450 shipped for the 5spd swap
The M20 has unknown mileage but was clean and well kept. I have a video of it running before I pulled it out. It ran very strong and smooth. I actually felt bad about removing this motor as the car was 100% all original bone stock 2 owner car in very nice condition. Local pickup only or you can arrange freight pickup.
If there are any serious buyers I will post the video or email it to them.
$300 for the complete motor, wire harness, and ECU
If you come pick all this up locally you can have the engine and transmission swap for $500
5spd Swap Includes:
- 5spd Pedal Set
- Used Clutch
Does not include:
