A few E30 parts including brake pedal, driveshaft, flexplate, etc.
  • wakeboardr42393
    • Apr 2013
    • 186
    Pick up in Garfield Heights, Ohio, 44125 or I will ship (good shipping prices) to you at your expense.
    I may be willing to separate some things if you only need part of something or a specific part. let me know ;)
    • Window Regulator for Sedans. $33 shipped. [51331911384] Front Passenger Side w/o Motor. Will fit cars up to March of 1988
    • M20 Engine Block Rear Covering Plate. $8 shipped. [11141280826]
    • WORKING automatic transmission with torque converter $20: I want this gone!! from an 87 325is)[24001216571, 24001466371, 24001468222] I only drove the car for one day with the auto trans. it went through all of the gears, and engagement into drive and reverse from park was pretty smooth. I've never had an e30 before this, but I noticed that when in drive and driving normally, the trans seemed to hold gears longer then i'm used to on other makes & models of cars. I'm not sure if that's how the trans is supposed to work (to be "sporty" or whatever) if the kickdown cable needed adjustment, or if there is some other issue. I only drove on it for a day, so i can't really attest to any condition besides that it works. without guibo.
    • Guibo $9 shipped: [26111225624] looks like it's in decent usable shape as far as i can tell.
    • Flexplate (automatic flywheel) $20 shipped: [11221716276, 11221716275]
    • Torque converter driving dog (triangle piece) $10 shipped: [24401215514]
    • Shim for flexplate $5 shipped: [11221710038]
    • Auto Shifter bezel and brush (free): [51161904786, 51161904758] on the bezel, some of the mounting tabs and stuff are broken; it was partially glued on. Also have the "brush" (not broken, but the "hairs" are bent, as photo shows).
    • brake pedal / pedal box assembly $10: [35111157719, 35211155018, 35211160950, etc...] without spring, but does include brake light switch.
    • throttle spring $1: [35411106273]
    • auto transmission crossmember $8 shipped: [24711128371] without mounts
    • twin-mass/ dual-mass flywheel $50 shipped: [21211225979]
    • bellhousing cover/bowl reinforcement w/ "stopper" $15 shipped: [11141286342, 11811132177]
    • Auto shifter and linkage $5: not sure. lol
    • auto trans dipstick $2: [24111216250]
    • auto trans dipstick tube/oil fill tube $3: [24111217436]
    • driveshaft tunnel brace $5: from an 87 325is. not sure the part number; can't find it on realoem.
    • Clutch and pressure plate for dual-mass flywheel $66 shipped: this clutch and pressure plate are for a dual or twin-mass flywheel only; these specific parts were pulled from an 87 325e.
    • Trailing arm bushing $5 shipped: [33329061945] brand new from Lemforder. This is only a single bushing for sale.
    • Auto Driveshaft $60: [26101226417] check this part # on realoem.com for compatibility with your car. comes with support bearing & mount attatched. does not come with guibo. came from an 87 325is. This driveshaft looks like a replacement/remanufactured item. I don't think it's the original one that came with the car haha; looks newer then that. plus it has a bar code sticker on it, and the joints look like they may have been rebuilt.
    • throwout bearing $44 shipped: [21517521471] Brand new from BMW. Genuine BMW part.
    • Clutch & pressure plate for m20 $77 shipped: for single-mass flywheels.
    '87 325is [because racecar]
    '81 Kawasaki KZ550 LTD {summer dd}
    '97 Subaru Legacy Outback Limited (winter dd)
  • wakeboardr42393
    • Apr 2013
    • 186
    auto gear selector handle w/pull rod SOLD
    • wakeboardr42393
      • Apr 2013
      • 186
      bummpity bumperoo
      • wakeboardr42393
        • Apr 2013
        • 186
        Price drops!
