Bump
FS: 5-lug Kit | E36 & E46 Hub & Caliper Adapters for E30! | Rear Big Brake Kit
Prices have been adjusted, since our country has changed to Euro, and also because the supplier has raised them a bit.Comment
Bump :)Comment
Bump :)Comment
Hey Max or anyone else who installed the kit. I havent come around to install my kit, and need to get the proper info to buy the right wheels.
How much wider/narrower is the final offset for the front, comparing stock e30 to the e36 hubs?
PS: bump---E30 320i Hennarot 1984 Sedan---
The front is widened by 11mm on each side. You can use this calculator to see how it will look comapred to your current wheels: http://www.willtheyfit.com/
When calculating - the front adapter is acting as a 11mm spacer, so when you fill your new wheel setup do the new wheel ET minus 11. So if your new wheel ET is 13, with the adapters your ET will be 2.
Depending on how you want your car to look chose the corrent offset :)
I like when the offset is closer to 0, so all my wheels are ET 0-15 :)
Max.Comment
yeah, thats the one im using, its really helpful. but since i didnt know how much wider the hubs were, i was a bit lost.
i figured it out that they would end up wider, which is a good thing in this case cause i need to get away from the inner wheel arch.
once i get kamotor's flares, i will get the new wheels and rubber. cheers.---E30 320i Hennarot 1984 Sedan---
Biggest front option with the E36/E46 bracket is the E46 330 brakes, size is almost like E46 M3. If that is too small - you can get a E38 Brembo bracket that will use the same 330 rotor but bigger Brembo calipers from and E38. If you need something else - that will have to be custom.
For the rear, biggest you could go would be E46 M3 rear brakes.Comment
Those calipers are incredibly rare and expensive. Have you thought of creating a bracket for a cheaper more available caliper? Something from Wilwood perhaps?Biggest front option with the E36/E46 bracket is the E46 330 brakes, size is almost like E46 M3. If that is too small - you can get a E38 Brembo bracket that will use the same 330 rotor but bigger Brembo calipers from and E38. If you need something else - that will have to be custom.
Currently no option like that is available.
Only the original BMW calipers.
Front caliper brakcets without the hub sleeves - 90 EUR.Comment
