FS: 5-lug Kit | E36 & E46 Hub & Caliper Adapters for E30! | Rear Big Brake Kit
  • Max399
    • Feb 2013
    • 991
    #286
    Try using this calculator http://www.willtheyfit.com
    You can compare to the existing setup. Remember to remove 11 from the ET of the new wheel, since it is getting spaced out a little.
    5-lug Kit | E36 & E46 Hub & Brake Adaptor for E30!
    Leave feedback about my transactions!
    • Art5
      • 61
      #287
      I just checked on realoem, e36 sedan rear bearing has same dimensions as E30, but different part number for some reason
      • Max399
        • Feb 2013
        • 991
        #288
        Yes, also Z4 rear bearing and E90 rear bearing. But keep in mind E30 had two different rear bearings, small and big. And you cannot tell till you take the measurements.
        • Art5
          • 61
          #289
          But why would part numbers be different?
          I have 5-lug adapters for rear, but if regular e36 rear bearings would work, i would sellmy adapters.
          I still have to overhaul my rear suspension, my might as well change hubs, which cost all together $100
          • Max399
            • Feb 2013
            • 991
            #290
            You would face different caliper mounting points that way. Part nuber is different since its a different part :)
            • Art5
              • 61
              #291
              You mean rotor will sit further away from caliper?
              You said different part numbers are different parts, but why dimensions are listed same for both parts?
              • Art5
                • 61
                #292
                Here e36 rear hubs and bearings could be bought for very cheap and anywhere.
                • Max399
                  • Feb 2013
                  • 991
                  #293
                  Have 3 kits in stock, can do next day shipping.
                  • Max399
                    • Feb 2013
                    • 991
                    #294
                    Bump. Two kits left.
                    • Max399
                      • Feb 2013
                      • 991
                      #295
                      Bump. Two kits left for next day shipping.
                      • Max399
                        • Feb 2013
                        • 991
                        #296
                        Bump
                        • Art5
                          • 61
                          #297
                          Just checked for bearings for E46 and E30 for rear hubs and advanceautoparts lists same part numbers.
                          • Art5
                            • 61
                            #298
                            Got the kit today
                            • Max399
                              • Feb 2013
                              • 991
                              #299
                              Bump
                              • rotem
                                • Sep 2015
                                • 1
                                #300
                                bump sent you a pm !
