FS: 5-lug Kit | E36 & E46 Hub & Caliper Adapters for E30! | Rear Big Brake Kit
  • Max399
    • Feb 2013
    • 991
    #346
    Shoot me a PM when ready :)
    5-lug Kit | E36 & E46 Hub & Brake Adaptor for E30!
    Leave feedback about my transactions!
    • Max399
      • Feb 2013
      • 991
      #347
      Bump.
      • kristov
        • 222
        #348
        Can you still use the ABS-sensor with this kit?
        • bmw-slangen
          • Dec 2009
          • 27
          #349
          Interesting thread, I just have a few question (which I think many other are also wondering about).
          Q1 : What's the thickness of the (inner) spacer part of the sleeve?
          From own experience and tried some, 7.5 mm is the extreme absolute minimum but should be considered too thin (the brake disc was then only 0.5 mm from the steering ball joint). This seems to be thicker, is it around 12-13 mm maybe?
          Q2 : Is it an interference (light or hard) fit or slip fit for the sleeve onto the axle stub?
          Q3 : Is it an interference (light or hard) fit or slip fit for the wheel bearing onto the sleeve?
          • kronus
            • Apr 2008
            • 13012
            #350
            it's 12mm, interference fit both ways
            cars beep boop
            • bmw-slangen
              • Dec 2009
              • 27
              #351
              Yeah, 12 mm makes sense (and is more into the comfort zone).
              Thanks for quick reply!
              • kristov
                • 222
                #352
                Can you fit the e46m3 hub with this kit?
                • Max399
                  • Feb 2013
                  • 991
                  #353
                  Yes, its 12mm.
                  As far E46 M3 hub - if it does not differ from the stock E46 - then yes.
                  This was only tested with stock E36 and E46 hubs.
                  • Max399
                    • Feb 2013
                    • 991
                    #354
                    Bump. Discounts available on multiple orders.
                    • LowR3V'in
                      • 4209
                      #355
                      So basically this is an adapter so you can mount the e46 330 hub/brakes right?
                      Is there any downside to this thing on a technical level? Like the bolt holding it unscrewing, or breaking off? Materiel cracking ect?
                      • Max399
                        • Feb 2013
                        • 991
                        #356
                        Yes, an adapter to fit E36/E46 hub and rotor/caliper onto E30 strut.
                        If there were any downsides like that - it would not be produced :D
                        The only downside i can think if - is the offset change. 11mm on each side in the front.
                        • autopia
                          • Dec 2016
                          • 1
                          #357
                          still available for sale
                          Hi Max399,
                          read your post thus I have some questions,
                          I have a e36 m3 with 312mm rear discs and would like to retrofit AP Racing 4pot caliper CP5144-117 which is the stad upgrade on the rear axle for the E46 M3.
                          would your adapters for upgrading an e36 m3 rear axle with a e46 rear brake caliper retaining the e36 312mm oem m3 rear brake disc?
                          Thanks for having a look at it and getting back to me,
                          I wish you all the best until we hear from each other
                          with kind regards
                          Thomas
                          • Max399
                            • Feb 2013
                            • 991
                            #358
                            Bump
                            • GIJew
                              • Nov 2016
                              • 3
                              #359
                              Pm'd
                              • Max399
                                • Feb 2013
                                • 991
                                #360
                                Bump.
