Hello everyone,
Have you ever wanted to convert your E30 to the 5x120 PCD and also have a bigger brake option? Well now you actually have a chance to do that! And you don’t need the pricey E30/E36 M3 parts :)
We have a lot of different kit’s that you can choose from.
For the front, all of the kit’s consist of hub sleeves, caliper attachment bracket and a locking nut.
The hub sleeves are used as a spacer over the original E30 spindle to fit any of the E36 or E46 hubs, and the caliper bracket is used to space out the caliper so you can mount it on you’r E30 strut with any E36 or E46 rotor. Any E36 non M3 or E46 non M3 caliper can be used. Also there is a bracket that will allow you to fit the E38 Brembo caliper in the front. The locking nut is used to lock the the hub nut in place, in order to use the locking nut – you have to make new thread inside the E30 spindle, it is reverse thread and the bolt is M16x1.5LH. Original E36 dust cap does fit!
Keep in mind that when using the front kit the track is widened by 12mm on each side.
This is how the they look, this is the kit with the regular E36/E46 brakes bracket:
And this is the kit with the E38 Brembo caliper bracket:
Here is a comparison to the original E30 strut and brakes (Right) vs my kit on the left with a spacer on it:
For the rear there are also a few options, but all of them consist of using the E36/5 (Compact) trailing arms. They can be divided in two categories, one category is for the drum brake trailing arms, and the other is for the disk brake trailing arms (TI).
EDIT: As of 2016/04/18 there is another option available for those who use E30 trailing arms with Z4 hub's. You can use 325-330 E46 rotor and caliper with this setup. More info can be found over -here-
Keep in mind that when using E36/5 trailing arms the track is widened on each side by about 5mm.
For the drum trailing arms there are two variants – one is for a single caliper conversion and the other is for dual caliper setup, ie you convert the drum trailing arms to disk trailing arms. Any E36/E46 rear rotor and caliper can be used.
Single caliper bracket:
Dual caliper bracket:
As for the disk trailing arms (TI), there are also 2 variants, one is a bracket that allows you to mount rear E46 M3 brakes on the TI trailing arms and the other is a bracket to allow you to mount any E36/E46 rear caliper and rotor.
The E46 M3 rear brake’s bracket:
And the regular E46 328 and 330 rear brakes bracket:
Here's how they look on a car with the 330i brakes:
Basically you can say that’s it’s more of a big brake kit.
Keep in mind that when using any of the rear adapters you are left with no handbrake. Only option is to use the drum trailing arm dual caliper adapter – that way you can setup one caliper to be hydraulic handbrake.
Ok, so now the fun part – the prices.
EDIT 2015.01.06
The prices have changed, since our country has changed to Euro.
And also because the supplier has raised the prices a bit.
- Front hub sleeves with E36/E46 caliper bracket’s – 190 EUR
- Front hub sleeves with E38 Brembo caliper bracket’s – 190 EUR
- Front hub sleeves without any caliper bracket’s – 90 EUR
- Rear E36/5 disk trailing arms bracket to fit E46 M3 brakes – 90 EUR
- Rear E36/5 disk trailing arms bracket to fit E46 328 or 330 rear brakes – 90 EUR
- Rear E36/5 drum trailing arms bracket for one caliper setup – 100 EUR
- Rear E36/5 drum trailing arms bracket for dual caliper setup – 110 EUR
Shipping to US is 35 EUR. If taking multiple kit’s the shipping price will go up, because they weight more. When taking multiple kit’s some discount’s may apply. Shipping to other countries is also available. All items are shipped with a tracking number.
Also, old discussion on these can be found over here: http://www.r3vlimited.com/board/showthread.php?t=304699
Most common questions and answers to them:
- Has anyone actually installed these?
Yes, user pandaboo911 has installed them. The installation process can be seen in his build thread, starting from this post: http://www.r3vlimited.com/board/show...110&page=9#122
The rear kit has also been installed by user Julien, and the build thread can be found here: http://www.r3vlimited.com/board/show...09#post4262009
One more install of the front kit by user Corey@Track.One can be seen over here: http://www.r3vlimited.com/board/show...59#post4284059
Front install by user TimKninja can be seen over here: http://www.r3vlimited.com/board/show...60#post4363660
- Do you have any feedback?
Yes, my feedback thread can be found over here: http://www.r3vlimited.com/board/showthread.php?t=312662
- What else do i need to finish the swap for the front?
To finish the swap you would need E36 or E46 hub assembly, rotors and calipers with carriers.
Brake pads of course.
- What about ABS?
You will have to find a way of mounting the ABS sensor yourself. Or you can check this post for some ideas: http://www.r3vlimited.com/board/show...699&page=9#133
- What are the biggest brakes i can use?
Since these do not fit M3 brakes, the biggest brakes you can use are E46 330 brakes. They are 325x25.
To compare - M3 ones are 325x28.
But keep in mind, that with 330 brakes - the smallest wheel you can use is 17 inch.
Here is a picture to compare different E46 brake sizes, from left to right:
323, 320/325/328, 330, M3, M3 competition.
Here is a little table i made to compare brake sizes:
- How hard is it to fit them? Do i need to play a lot?
All you have to do is fit the adapter with the hub on the spindle, for that i would recommend heating the adapter sleeve with a torch and then sliding it in. After its halph way in - push it to the end by tightening the other halph of the adapter. In order to attach the caliper itself - the carrier must be notched a little bit to clear the mounting points. Here is a picture that shows what you need to grind away:
And here is how it should look after you grind it:
- How can you accept payment, how will you ship?
I can accept payments via PayPal, will ship by AirMail with a tracking number.
If you have any more questions feel free to ask :)
Max.
EDIT 2015.01.06
- What about ABS?
Max.
