Well, I have been collecting stuff for my e30 swap for about six years and I hate to see it go, but I have medical bills to pay. I beat cancer, but it has cost me a lot of money and the bills need to get paid. I will answer in the order I get things as fast as I can. (which is not always fast, sorry) I can get pictures of anything, but most of it is new.
I hate to do it, but I can't afford the paypal fees, so I would appreciate enough extra to cover them. I will ship it anyway you want if you are paying the bill. I live north of Seattle, in Washington state.
I have a lot more to come, full suspension, big brakes, mt2 kit, but I am holding off.
S50 & ZF 5 Speed – About 78,000 - $2500 plus shipping. (this is basically a complete motor and transmission with harness, ecu, pretty much all bolt on stuff, I stripped it to the block, but have everything. Car VIN available by request)
Turner/Conforti Stage 3 Kit (+57hp / +30ft-lbs) $2400 new $1500 plus shipping ==SOLD==
- Schrick Cams
- Euro HFM
- 24 lb injectors
- Matching High Performance Chip
NGK BKR6EIX Spark Plugs - new - (was $42+shipping) $37 shipped
BavAuto High-Performance Ignition Coil Set s50 - new (was $275+shipping) $240 shipped
Oxygen Sensors - new (was $204+shipping) $180 shipped
Camshaft Position Sensor - new (was $128+shipping) $115 shipped ==SOLD==
Crankshaft Position Sensor - new (was $82+shipping) $70 shipped ==SOLD==
Knock Sensors - new (was $114+shipping) $100 shipped
ARD Underdrive Pulleys - new - $150 shipped - ==SOLD==
Silicone Vacuum Hose Kit - new (was $30+shipping) $25 shipped
ARP2000 Head Bolts - new (was $185+shipping) $165 shipped==SOLD==
Elring Head Gasket Set - new (was $195+shipping) $180 shipped
Valve Spring Retainer Set - new (was $280+shipping) $260 shipped
Valve Keeper Set - new (was $84+shipping) $74 shipped
Beisan Single Vanos Seals Repair Kit - new (was $30+shipping) $25 shipped==SOLD==
Beisan Single Vanos Rattle Repair Kit - new (was $30+shipping) $25 shipped==SOLD==
Oil Pan Gasket set - new - (was $63+shipping) $53 shipped ç==SOLD==
E36 Euro Oil Filter Housing - $240 plus shipping==SOLD==
Euro cooler and lines - $140 plus shipping ==SOLD==
Bavarian Auto FXC2 code reader reset tool (was $149 + shipping) $125 shipped
UUC Oil Center - new - $100 plus shipping NOT AVAILABLE FROM UUC CURRENTLY
Prosport Gauges - new BLUE/WHITE 52mm series - oil temp, oil pressure, & water temp (was $154+shipping) $140 shipped
BMP e30 Gauge Console - new (was $85+shipping) $75 shippedç==PENDING
UUC Stage 2 Lightweight Aluminum Flywheel with clutch and pressure plate $550 plus shipping
- M5 Clutch
- M5 Pressure Plate
E36 325i slave cylinder - new (was $59+shipping) $49 shipped
E36 325i UUC Stainless Steel Clutch line - new (was $29+shipping) $25 shipped
AKG Trans Mounts - - (was $75+shipping) $65 shipped ==SOLD==
UUC Clutch Stop - new - $15 shipped[COLOR=#3e3e3e]==SOLD==
Throughout Bearing - new (was $45+shipping) $37 shipped==SOLD==
Mishimoto Radiator - new (was $340+shipping) $240 shipped ==SOLD==
Aluminum Thermostat Housing - new (was $30+shipping) $20 shipped ==SOLD==
80 degree Thermostat - new (was $18+shipping) $14 shipped==SOLD==
Spal 16" Pusher Fan 2047 - new (was $150+shipping) $135 shipped
80/88 Degree Temperature Sensor - new (was $25+shipping) $20 shipped ==SOLD==
Samco Silicone Radiator Hose set, blue - new (was $100+shipping) $80 shipped==SOLD==
Silicone Vacuum Hose Tubing kit, blue - new (was $30+shipping) $25 shipped
Here is the list of the main swap parts I have. Some of parts will be listed in the performance parts thread instead of here, like the cooling system for example. New parts are listed, the rest are in at least good plus condition.
E34 oil pan, dip stick, and tube - $130 plus shipping ==SOLD==
E34 throttle cable - new - (was $31+shipping) $25 shipped ==SOLD==
E28 M5 motor mounts - new - (was $65+shipping) $55 shipped ==SOLD==
E36 motor mount arms - $55 shipped
S50/e30 wiring harness adapter - $150 shipped ==SOLD==
413 red label DME - $80 shipped==SOLD==
Swap DME Mount Adapter - new - (was $31+shipping) $25 shipped ==SOLD==
AKG Trans Mounts - new - (was $75+shipping) $65 shipped ==SOLD==
1492mm e36 Driveshaft $100 plus shipping==SOLD==
2.79 LSD - best offer
3.25 LSD - best offer
Correct Swap Brake Booster $75 plus shipping (e21 if I remember right) ç==SOLD==
The following is a custom fitted exhaust system. For the most part, this should bolt up to your swap and exhaust mounts eliminating the need to fabricate mounting for the swap. This setup is arguably as good as you are going to get for your swap. Excellent performance boost and that kind of Euro sound without the heavy rasp. This is worth every penny!
E36 Euro headers
E36 Euro midpipes
E36 Stromung Stainless catback (all e30 ready) $1500 + shipping
e36 EXHAUST - mid-pipe and catback ODB1
I bought the exhaust to get the mid-pipe for my s50 conversion and ended up going with a euro exhaust, so I never used it. Supposedly, the catback has some miles on it but is good. The cats are supposed to be new, or newer. But honestly, I have never heard them running or used them. With the oxygen sensor they should go about four hundred, but I would take $250.
e36 M3 DASH - dash, gauges, heating, lights, etc. $300 - ask about any miscellaneous modules from under the dash
e36 HEAD LIGHT ASSEMBLY - Drivers side with bulbs $75
e30 MSDS shorty HEADERS - m20 ceramic coated $175
- Schrick Cams
- Euro HFM
- 24 lb injectors
- M5 Clutch
- M5 Pressure Plate
E36 Euro headers
E36 Euro midpipes
