cleaning out the garage, have a bunch of stuff for sale
I only accept paypal, all prices plus shipping
you can check out my feedback here http://www.r3vlimited.com/board/showthread.php?t=151043
e36 window switch
20
e30 trunk tool kit
20
diagnostic connector bracket
10
m20 motor mounts
20
ebrake accordian
20
e30 hood brackets
20
rear sunroof vent in the trunk
20
relay cover
10
driver wiper arm
20
thermostat housing and covers 20 each
thermostat housing modified and the hose for the throttle body has been plugged
34
alternator bracket
30
oil return tube and spring
10
distributor cover plate and bracket
20
bracket for the subframe to keep the engine from sliding forward
20
m20 motor mount bracket and heat shield
20
plastic m50 thermostat housing
20
abs wiring loom
10
irvine bmw license plate frame
20
rear carpet section
20
m20 performance chip
50
m42 wiring loom cover
20
rear seat belt
20
e30 hood hinge, alpine white 2
20
modified m20 throttle bracket to clear sparco strut bar
20 each
late model turn signal driver side
10
rubber pedal cover
10
rubber spring pads rear lower
10
rear parcel shelf
cowl covers small crack near the hole for the wiper driver side
20
16spal fan rubber grommet to seal against the radiator
20
m20b25, stock airbox
40
Modified center console
10
M20b25 upper timing cover.
20
the famous JAPAN ANDREW gave me this euro plate a few years back when i went to drop off some parts he bought from me.
30
intake boot
10
m50 valve cover
20
e36 window switch
20
e30 trunk tool kit
20
10
m20 motor mounts
20
ebrake accordian
20
e30 hood brackets
20
20
relay cover
10
driver wiper arm
20
34
alternator bracket
30
10
20
20
20
20
abs wiring loom
10
20
rear carpet section
20
50
20
rear seat belt
20
20
20 each
10
rubber pedal cover
10
10
rear parcel shelf
20
20
40
10
20
30
intake boot
10
m50 valve cover
20
