Wert MotorSport - Heated Seat Kit
  • torreira
    • Aug 2013
    • 260
    E30 Heated Seat Kit
    This is a project I have been working on to help all you guys out
    there keep your bums warm. Only a handful of E30s came fitted
    with the heated seat option. Now, twenty some-odd years later,
    sourcing a working OEM unit can be quite a hassle. Things get old
    and rot out. The heating pads are not meant to last forever and
    switches begin to go.
    My goal is to provide a affordable alternative to the OEM Option.
    I have put a lot of thought into product to make sure it will last long
    and work efficiently. Below is some information regarding what this
    kit will include.
    Basic Information
    I had been toying around with the idea of making heated seat retrofit
    kits using modern heated seat pads. I have a supplier for the pads already and am
    set on a design. The pads used are from a US company that makes
    carbon fiber heating pads for car seats and other applications. They
    heat up fast and stay at a comfortable level.
    These pads can be used in any seat you like but i am open to custom
    set ups for optimal heating for different sized seats and possible rear
    pads for sedans. I can use different size pads for recaros and other
    sport seat types and comfort seats.
    OEM Switch
    Aftermarket Switch
    Features:
    -Electronic thermostat (built into each pad) regulates the electricity / temperature
    circulating within the carbon fiber seat heating pad. This system regulates the flow of
    power and maintains a narrower temperature range whether in a high or low setting.
    Example: The high setting will have a constant range between 120°F to 125°F. The low
    setting ranges between 110°F to 115°F. These respective temperatures are maintained
    at these respective levels.
    Kits:
    - 2 Seat Kit (with Aftermarket Switches)
    - 2 Seat Kit (with New OEM Switches)
    - 2 Seat Kit (for use with your own OEM Switches)
    Each Kit Includes:
    - (4) Carbon Fiber Heat Pads
    - (1) Custom Wiring Harness
    - (2) Switches
    - (2) Dual temperature control module
    - (1) Installation Instructions
    I do not have any kits currently for sale.
    The wait time will about 4 weeks
    to have them finished
  • mpowerful
    • Jul 2013
    • 1273
    Pics of aftermarket switches?
    • yahh
      • Aug 2012
      • 803
      Let me know what you can work out for a set of Evo 9 Recaros (pictured below)
      s50 86 325e Project
      S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
      Feedback Thread
      • torreira
        • Aug 2013
        • 260
        Edited into post. I am still looking for an OEM style rectangular aftermarket switch
        • torreira
          • Aug 2013
          • 260
          Those seats can use the same kit for sport and vinyl seats. It requires you to place the pads under the fabric. Im not sure how easy that would be on those seats.
          • yahh
            • Aug 2012
            • 803
            I'm in for a set with aftermarket switches.
            s50 86 325e Project
            Feedback Thread
            • torreira
              • Aug 2013
              • 260
              One Set with Aftermarket Switches Paid for going in Recaro Evo 9's. Get them while they are cheap guys!
              • dsphil
                • 495
                I bought OE heating elements to fit into the slots between the leather and the lining. Heating is not so great but it does the job this winter. The heating elements you offer may have to fit between the padding and the lining for the sport seats with straight stitches like the one I have, though it probably fit better with verts, comfort, and the m3 seats.
                327is
                325es
                325es
                318is
                Fiesta ST
                E46 M3
                • torreira
                  • Aug 2013
                  • 260
                  A few orders are already trickling in. Thanks for all the support guys. These are getting more attention then I originally anticipated.
                  I saw this problem fairly early in the process of designing this kit. These new pads for the coupe are set warmer slightly then the OE pads and can be placed underneath the thin foam pad on the coupe sport seats with the same effect. Although it might be slightly less warm then the Comfort/Convertible/M3 sport seats.
                  Thank you for pointing this out i forget to mention it in the post.
                  • newman8r
                    • Feb 2014
                    • 683
                    When I get some things squared away count me in!
                    • mpowerful
                      • Jul 2013
                      • 1273
                      Why is price on the kit with no switch more expensive than the one with aftermarket switch?
                      • arch4ngel
                        • Dec 2008
                        • 791
                        Great idea!
                        I'll be ordering a set once my swap is done.
                        Project
                        Feedback
                        • torreira
                          • Aug 2013
                          • 260
                          because it includes a different harness to be able to be used with the OEM Switches.
                          • Killacortes
                            • 1937
                            Very nice! Awesome price too
                            r3v does not fuck around. First you get banned, then they shoot you
                            • gkurey
                              • 882
                              PM sent, this looks great!
