"Sintered" timing gears + accessories -- $75.00
  • JasonInSeattle
    • Mar 2014
    • 3
    Hi guys -- I had a 528e for a bit, and now I have this stuff laying around and am not going to use it; should also be compatible with 325e I believe?
    Please verify that these are the parts you need for your car; I believe these will work on all early Eta motors but I do not know for sure...
    I have positive reputation on mye28.com if you want to check. Here's my ad from over there:
    Upgrade your pre-86 Eta to the good timing gears -- these are the "sintered" timing gears to upgrade from your "stamped" gears.
    This is the cam gear, intermediate shaft gear, lock bolts for both gears (two new lock bolts), the necessary keyed washers for both gears, proper cam gear "cover", and proper distributor rotor mount...
    Here is the invoice from Pelican:
    Item Name Item Price Quantity Item Total
    11-31-1-714-795-BOE $1.75 1 $1.75
    Genuine BMW Part: Flat Washer
    - This part may be shipped directly from the manufacturer.
    - This is a special-order OEM part and is non-returnable except
    for warranty replacement.
    11-31-1-730-610-BOE $3.75 1 $3.75
    11-31-1-717-180-BOE $1.00 1 $1.00
    11-31-1-714-798-BOE $9.25 2 $18.50
    Genuine BMW Part: Lock Bolt
    11-31-1-713-475-BOE $3.50 1 $3.50
    7-COVER
    - This is a special-order OEM part and is non-returnable except for
    OST-11-31-1-713-064-M9 $17.00 1 $17.00
    Camshaft Adapter for Ignition Rotor, E30 325i/is/iC/iX; E34 525i; E28
    528e (through 11/86) -
    - This part is currently out of stock at our primary warehouse,
    however we may be able to source it from an alternative supplier.
    11-31-1-717-398-BOE $25.50 1 $25.50
    Genuine BMW Part: Gear Wheel,Tooth Belt
    11-31-1-714-988-BOE $42.50 1 $42.50
    $75.00 plus shipping; I take PayPal; PM me!
  • JasonInSeattle
    • Mar 2014
    • 3
    Still available! :D
    • JasonInSeattle
      • Mar 2014
      • 3
      Offers?
