Is your shifter feeling tired? This is all you need to rebuild it. It's a very easy half day job on E30s. If you have thin hands you don't even need to remove anything in the way.
Everything is brand new just as it came from Pelican Parts (Kit PEL-SKSBE30-06N).
According to pelican, this kit fits all E30s with 6/86 to 8/89 build dates. Please validate the part numbers with RealOEM for your car. E30s came with different shifters.
Price: $50 shipped
Here's all that's included:
1 07-11-9-932-863-BOE 1 Selector Rod Circlip
2 23-41-1-466-110-M9 1 Ball Cup Bushing for Shift Lever Upper
3 23-41-1-466-134-M200 1 Dowel Pin for Shift Rod Joint
4 25-11-1-203-682-M9 1 Tension Bushing for Shift Rod Coupling
5 25-11-1-220-199-M9 1 Shift Rod Spacer Shim, 10.2 X 16 X 0.65
6 25-11-1-220-228-BOE 1 Shift Lever Rubber Cap, Inside Shift Lever Assembly, 318i (1984-86)
7 25-11-1-220-439-BOE 2 Yellow plastic washer/bushing/shim for shift selector rod
8 25-11-1-221-214-BOE 1 Shift Lever Boot, Insulating Boot for Manual Transmission
9 25-11-1-221-243-M213 2 O-Ring for Shift Rod Joint Standard Transmission
10 25-11-1-221-849-M9 1 Locking Pin for Shift Lever Support Arm Bushing
11 25-11-1-434-194-M9 1 Rubber Buffer (Sponge) for Shift Rod Joint at Transmission
12 25-11-1-469-397-M92 1 Shift Tower Bushing for Shift Lever Pivot
13 25-11-7-501-309-M200 1 Shift Rod Joint, Standard Transmission
14 25-11-7-519-669-M213 1 Bushing for Shift Lever Support Arm (attaches at Transmission)
15 25-11-7-571-899-M9 1 Shift Rod Circlip at Shift Rod Joint and Shift Lever
Price: $50 shipped
