well i am starting to sell my turbo parts so please read all of this i will update as i can go through things
im am in no need to sell fast and would rather keep it than give it away i have no intentions of selling as a whole kit for a better price and money talks so if i get a better offer before money than i am sorry
all parts used for around 1000 miles took off because i needed a more reliable car as i am getting married in may
all price do not include shipping
if you pay with paypal you pay the 2.9% +.30 charge also
if you need to contact me...
email is vwandbmw521@aim.com aol screen name vwandbmw521
i will update this as i can, pictures will be available when i can get around to taking them in a day or so
with all that said here we go
garrett turbo t3/t4 ar .50 intake side 4 bolt discharge flange needs rebult has shaft play make an offer
pro turbo finland manifold adapter with t3/t4 turbo mount and wastegate pipe welded to it for a tial 46mm wastegate also jet hot coated black (some scratches) $300
tial polished 46mm wastegate (the big one) 16lb spring inside $300
tial 50mm blow off valve it is red has a 6-7lb spring in it $150
greddy catch can retangular in shape $75
19# fuel injectors and fuel rail $60
aftermarket oil cooler with adapter to fit on block also has fitting for the oil supply line and the two lines from the cooler kind of beat up but still works $45
down pipe jet hot coated black (some scratches) attaches to waste gate and 4 bolt outlet flange on a t3/t4 turbo i belive it is 2 1/2 inches and it has the flange for the rest of the exhaust and an o2 sensor at the end of it also $200
boost tubes jet hot coated has a flange for a tial bov $150
front mount intercooler fits at the bottom of the front valence 24 3/4 x 7 1/2 x 4 $250
k n air filter and intake tube located filter low and out of the way $50
super eta intake manifold ported and polished also has extra fitting in it for vaccum lines $200
ported throttle body (the butterfly valve was cleaned up) $100
aluminum coolant tank it is a box shape and mounted where the battery would mount in the engine bay (needs a pressuried cap) $80
electric fan 12" it can go either direction has small crack on frame but works fine $60
gauge cluster I belive it is from a 318 I know its not from a 325 because the rpms don’t read right 162597 miles motometer one broken tab $20
auto meter air fuel gauge $30
vdo oil temp gauge $30
7 t bolt clamps, 2 2 1/2 strait silicone adapters, 3 various silicone reducers, 2 45 degree silicone adapters, and 5 hose clamps $60
1/2" high pressure oil line, 250 psi, 10 feet, blue, $60
oil feed line and return line with fitting $50
greddy profect b boost controller $200
msd btm set up $160
tial 46mm aluminum wastegate mount flange $10
tial 50mm bov aluminum mount flange $10
cheap 3" cone air filter used for more than 1000 miles $5
2 motronic ecu dont know if they work number 0261200027 $20 each
2 earls -6 strait auto fit fitting $2 each
msd btm set up $160
