FS: Misc. E30 Parts, Timing Belt Kit, Dashboard
  • thowes24
    • Jul 2010
    • 121
    Up for sale are several parts from my former project 1989 BMW 325i. Some are brand new, never used and others are used.
    Nearly perfect E30 Dashboard - $200 OBO
    Has one small crack on the inside of the pocket.
    Black Coupe Door Cards with Black Arm Rests & Map Pockets - $100 OBO
    Tan Sedan Door Cards with Tan Arm Rests (not shown) & Map Pockets - $80 OBO
    Drivers Side Door Mirror, Black - $15
    M-Tech I Steering wheel - $70 OBO
    Needs new MTech tricolor strip
    Brand New BMW Hood Roundel - SOLD
    Part Number 51 14 8 132 375
    BavAuto.com Catalytic Converter Installation Kit - $35
    Never used, still in original packaging. Includes all the required gaskets, nuts and bolts.
    BavAuto.com Muffler/Exhaust Installation Kit - SOLD
    Never used, still in original packaging. This install kit is for stock style replacement exhausts. It covers all parts from the catalytic converter back.
    Gauge Cluster Trim Surround Piece - $25
    PelicanParts.com Water Pump Super Kit for 325i models built from 09/87-92, all new parts - SOLD
    This kit includes everything necessary to replace your timing belt and water pump. I paid $405 and never got around to installing it. Includes: New Water Pump and Gasket, New Thermostat and Gasket, Fan Clutch, Radiator Mounts, Radiator Cap, Fan Clutch Tool and Counter Holder, Upper and Lower Radiator Hoses, 12 oz. Redline Water Wetter Corrosion Treatment, Timing Belt (6 Cylinder Cars), Timing Belt Tensioner and Spring (6 Cylinder Cars), Timing Belt Service Decal (6 Cylinder Cars), Cam Flange O-Ring (6 Cylinder Cars), Cam/Intermediate Shaft Seals (6 Cylinder Cars), and Front Crankshaft Seal.
    Used E30 Exhaust and Catalytic Converter - $125 OBO
    Located in Atlanta, GA
    Can ship some items
  • xcx4x
    • Sep 2013
    • 184
    dibs on the roundel
    PMed
    • Richter
      • Dec 2012
      • 241
      Is the timing belt/water pump kit for an early or late model engine?
      RICHTER MOTOREN
      1987 e30 325is Zinno - Restoring
      2004 e46 325xi Alpine - Daily
      2003 e46 330ci Topaz - Sold
      1988 e30 325is Zinno - RIP
      2007 Honda Ody - Family Truckster
      '87 325is Restoration Build
      • fight4life28
        • Apr 2014
        • 821
        Brand New BMW Hood Roundel - $20
        Part Number 51 14 8 132 375( if still available could I send you the money at 5pm threw papal?)
        • rcsoundn1
          • Nov 2012
          • 3361
          you have everything I just bought DAMMITTT!!!! Ill have to consier this dash since mine is more cracks then notGLWS
          • ethurtee
            • Jan 2013
            • 1989
            • thowes24
              • Jul 2010
              • 121
              The timing belt/water pump kit is for a late model engine, 325i M20B25.
              • thowes24
                • Jul 2010
                • 121
                The roundel has already been spoken for. If anything changes I'll let you know!
                Let me know if you're interested in the dash!
                • 325Eblue
                  • Jun 2013
                  • 300
                  I have an 87 is that should work correct?
                  • thowes24
                    • Jul 2010
                    • 121
                    According to the kit listing from Pelican Parts, this kit is meant for E30 models 325/i/is/iC/iX built from 09/87-92. To be sure just check the build date on your car.
                    • 325Eblue
                      • Jun 2013
                      • 300
                      Okay check will do thanks
                      • 325Eblue
                        • Jun 2013
                        • 300
                        my vin decoder comes up with 04 / 21 / 87
                        not sure this works?
                        • thowes24
                          • Jul 2010
                          • 121
                          Bump! Make an offer!
                          • 325Eblue
                            • Jun 2013
                            • 300
                            I need the timing belt parts just unsure if they are all a good match?
                            • thowes24
                              • Jul 2010
                              • 121
                              I believe the fan clutch and one or two other parts is different for i cars built before 9/87. Check out this link for more on the different parts between the two kits:
                              http://www.pelicanparts.com/catalog/..._pg1.htm#item0
