No longer parting. Thanks guys. Mods delete
					M42 Engine Part-Out
	Tags: None
 $40 shipped with the fan clutch
 All brand new and unused OEM gasket
 BMW p/n Qty Description
 07119963041 4 gasket ring
 07119963130 1 coolant temp sensor o-ring
 07119963200 1 coolant temp sensor o-ring
 07119963355 1 timing chain tensioner o-ring
 11121721475 1 spark plug / valve cover screw profile gasket
 11121721476 3 spark plug profile gasket
 11121721546 1 head gasket
 11121721876 1 valve cover gasket
 11121721879 15 valve cover mounting bolt seal
 11141247837 1 profile gasket between outer upper and lower timing covers
 11141247849 1 profile gasket between inner upper and lower timing covers
 11141721919 1 upper timing cover profile gaskets
 11349059171 2 valve stem seals 2 sets = 16 valves
 11531721172 1 thermostat housing profile gasket
 11531721218 1 thermostat o-ring
 11611717761 1 intake plenum-to-intake trumpet profile gasket
 11611734490 1 profile gasket between upper and lower intake manifold sections
 11611734684 1 lower intake manifold profile gasket
 11621728983 2 exhaust manifold gasket plate
 12141727220 1 camshaft position sensor o-ring
 13531720251 1 fuel pressure regulator o-ring, large
 13531720252 1 fuel pressure regulator o-ring, small
 13541743261 1 throttle body-to-manifold profile gasket
 13641730767 8 fuel injector o-ring
 18301711969 1 exhaust manifold flange gasketComment
