CNC machining. aluminum/plastics/brass
    Originally posted by e30experiment View Post
    does it come with the o-ring? awesome.
    I can't remember off the top of my head.
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
      there is a listing on ebay w/o the o-ring so i ordered an o-ring for the sensor, same one. thanks.
        valve cover coil holder + cam sensor setup. this should catch interest?
        sorry for the crappy cell pics
          Coil on plug rack would be sweet.
          Drive it hard. Maintain it well.
          A Topless Memorandum
            Ive done a little of reading and research about the cps a few months ago when I started this thread. It has been in the back of my mind., I dont yet feel confident about making the Cam position sensor setup.
            Put it this way... I usually take something that I am about to make and do research plus my experience in the "engineering" background and I improvise to make such Item be easy to adapt and fix most flaws that could be encountered, and then I test it. In this case, I haven't yet gotten to the point of using such set up, therefore I cannot test it. I also don't have any experience with such set up.
            Whats so complicated? Well, having to deal with degrees and tdc, and the setup would have to be dead on to be useful for tuning data. Otherwise there goes your thousands of dollars.
            To make it simple... I will only make it if I have a well tested and proven set up.
            So.... Can I make it? Yes! Give me a drawing and I will make it exactly as the drawing. And treat it just like any other piece I make according to the drawing.
            But then the rest is on you (as in whoever wants it.)... You do the testing and try to make it work.
            Doesnt seem too complicated right? Well, It would be nice for me to work together with someone well informed, and also test it and be able to produce a well rounded product.
            I hope you guys can understand.
            COP? Easy. Just a bracket. Its function? Hold everything together. No science behind it.
            What is needed? Well, a strip of aluminum, and some research on whats a popular cop that can be used. Once you have that.. Measure, 3D model, Program, CNC Machine it. and done. Its just a time consuming process, but not complicated.
              This would be the simpler version
              "Fancy" one looking like the stock piece...
              Price... Im thinking:
              30$ for simple one,
              37$ for Shmancy one
              and 5$ extra gets you the fitting
                +1 on the cam sensor setup!
                  All Cam sensor Pages I have found so far...
                  Link
                  Link
                  Link
                  Link
                  Link
                  Link
                  If someone has input on this please help out.
                  I am willing to produce a distributor delete plate and a Cam Sensor Plate.
                  Maybe we can make a separate thread?
                  Someone make one...
                  Came across this in one of the threads listed. Looks similar to the bracket I made. Or should I say mine looks like it. Except this one looks to be 2 piece.
                  By the way, I did not see that one before I made mine.
                    thanks for the simple t-body design delete plate, arrived today! looks nice
                      can I still by the coolant cover?
                        m50 intake manifold flange
                        Looking for late model fogs, E39 Fog lights, cool cheap 17 5x120 wheels.
                          Are you still doing the TPS adaptors, I am keen to buy? Also do you do a blank distributor cap plate for when running wasted spark?
                          Link
                          Link
                          Link
                          Link
                          Link
                          Link
                          Someone make one...
                          T U R B O - M 2 0 - B U I L D
                          M U S C C O O
                            I would suggest making a coolant connector hose for m42. OEM shit is plastic?! Also, am I alone in the quest for a late model front license plate delete with the BMW lettering?
                              Shift knobs? Keychains?
                                Rocker arms?
