Hey guys,
Everything is being parted because I am leaving the military and moving back to Tennessee within a few months and I am already towing an S14 and having someone drive my M3 across the country while I drive the moving truck.
It kills me to have to Part out everything I have worked so hard to Learn and Build for the Past two years, but I hope someone will enjoy the parts as I have.
Please PM me with Parts you want (Listed or Not)
All Prices are O.B.O
Prices That have "Package" Next to it, indicate all of the below parts included. Otherwise parts are priced each.
PRICES DO NOT INCLUDE SHIPPING! (Unless we work something out)
ENGINE - $4000 OBO SOLD
THE FOLLOWING IS FOR THE FOLLOWING + ACCESSORIES
1997 S52 3.2L
65k Before Complete Rebuild.
< 1 Mile on Rebuild.
Cylinder Head: Work Performed
Thermally Cleaned
Mounting Surface Decked
Mounting Surface Crocus Cloth Polished
Camshaft Journals and Caps Crocus Cloth Polished
New Intake Valves
New Exhaust Valves
New Valve Springs
New Valve Spring Seats
New Valve Retainers
New Valve Guides
New Valve Keepers
New Valve Stem Seals
New Hydraulic Lifters
New Camshaft Studs and Hardware
All Threads Chased and Cleaned
Complete Top End Gasket Set
New Aluminum Thermostat Housing
New 88 Deg C. Thermostat
New Thermostat Housing Hardware
New Vanos Unit Plugs with Seal Ring
New Timing Chain Tensioner
New Upper Timing Chain Guide Rail
New Upper Timing Chain Hardware
New Vanos Chain Tensioner
New Valve Cover Studs (Cylinder Head to Valve Cover)
New Valve Cover Securing Nuts
New Cam Oil Cover
New Cylinder Head Flange
Engine Block: Work Performed
Thermally Cleaned
Magna-Fluxed
Block Painted White with Heat Resistant Paint
New ARP 2000 Studs Installed
Head Mounting Surface Crocus Cloth Polished
Oil Pan Mounting Surface Crocus Cloth Polished
Crankshaft Main Journals Crocus Cloth Polished
Crankshaft Connecting Rod Journals Crocus Cloth Polished
New Oil Squirters
New Glyco Main Bearingswaffles
New Glyco Rod Bearings
New Connecting Rod Bolts
New Main Bearing Bolts
New Front Main Seal
New Rear Main Seal and Hardware
New 45mm Freeze Plugs
Complete Bottom End Gasket Set
New Metal Head Ringed Gasket
New Timing Chain Rail - Crankshaft to Exhaust Cam Chain
New Flywheel Bolts
New Complete Oil Filter Seal Kit
New MAHLE Oil Filter
New Aluminum Water Pump With O-Ring
New Serpentine Belt
New Clutch Pressure Plate to Flywheel Bolts
New Upper and Lower Timing Chains
New Oil Pump Chain
E28 Green Engine Mounts
M50 Oil Pan
New Clutch Disk (Sachs)
NEW Oil Pan Gasket
NEW Oil Filter Housing Gasket
VIDEOS OF IT RUNNING.
Intake:
M50 Manifold
New Manifold Gaskets
New Intake Manifold Idle Stabilizer
New Intake Manifold Studs
New Throttle Body Hardware
New Throttle Body Gasket
NEW E34 Throttle Cable (Broken Retaining Clip)
Exhaust:
Raceland Shorty Headers
New Metal Gasket Set
New Exhaust Studs
New Copper Exhaust Collar Bolts
New OBD2 02 Sensors
WIRING - $200 OBO
OBD2 Wiring Harness Hard Wired (Fuel, Ignition, Starter)
Blue Sea 5031 ST Blade Fuse Block (12 Circuit with Negative Bus)
ANL In-Line Fuse Block
"Hella" Master Kill Switch with Removable Key
Individual 30a Relays (I have 10)
TRANSMISSION - $200 OBO
5 Speed GETRAG
SOLD - Garagastic Swap Brace
SOLD - NEW Clutch Slave Cylinder
ENGINE MANAGEMENT - $400 SOLD
Kassel Performance MS41.2 TUNE with M50 MANIFOLD
+12Hp +10Tq
7,200 Rev Limit
EWS Delete
Secondary Air Pump Delete
Post-Cat O2 Sensors Delete
Muffler Flap Delete
No Emissions CEL
WHEELS + SUSPENSION - OBO
SOLD - NEW BC Racing BR Type Coil-Overs 10k Front 12k Rear
SOLD - (x4) 17x8 Square: BBS RC090 Style 5's (Has Center Caps, Missing Some Hardware)
$200 - (x4) Brake Rotors and NEW Pads
SOLD - (x2) 20mm 4x100 Spacers
SOLD - (x2) 5mm 4x100 Spacers
$15 - (x8.) 5mm Extended Lugs
$10 - (x8.) Regular Lugs
OTHER PARTS PACKAGE - OBO
$300 - SPARCO SPEED 2 Racing Seat
$200 - ASD Motorsports Upright Hydraulic Hand Brake with Willwood Master Cylinder and 5/8ths Pass-Through Kit with Hardware
$200 - Complete Black Interior
$100 - Front Subframe
$100 - Rear Subframe
$100 - Team Tech 5-Point Racing Harness
SOLD - E30 VDO CLUSTER 143,348 Miles Perfect Condition
SOLD - E36 Steering Rack
$50 - E30 Steering Rack
PENDING $50 - S52 AC UNIT
$50 - E30 ABS UNIT
$50 - LCA (EACH)
SOLD - 18LB BOSCH Green Top Injectors
$50 - OBD2 Fuel Rail
$50 - OBD2 Throttle Body
$50 - Sway bar + Hardware
$25 - Early Steering Wheel
$25 - Box of Random parts
Offer - Misc Trim Pieces
BODY PARTS - OBO
All Parts are Alpine White
$300 - Shell (Gutted, Sound Deadening Removed, Tubular Front, Rear Tire well Cutout)
PENDING $75 - Dash NO CRACKS
$50 - Each Sedan Door (Glass Included)
$50 - Trunk
$50 - Hood (Has Cutout over Exhaust)
$50 - Tail Lights with Pig Tails
PLEASE ASK ME IF YOU NEED SOMETHING THAT IS NOT LISTED!
1997 S52 3.2L
Thermally Cleaned
New Intake Valves
New Exhaust Valves
New Valve Springs
New Valve Retainers
New Valve Guides
New Valve Keepers
New Cam Oil Cover
Thermally Cleaned
Magna-Fluxed
New Oil Squirters
New Front Main Seal
New Flywheel Bolts
New Serpentine Belt
New Oil Pump Chain
M50 Oil Pan
NEW Oil Pan Gasket
Intake:
M50 Manifold
Exhaust:
New Exhaust Studs
New OBD2 02 Sensors
WIRING - $200 OBO
5 Speed GETRAG
+12Hp +10Tq
7,200 Rev Limit
EWS Delete
Muffler Flap Delete
No Emissions CEL
$50 - E30 ABS UNIT
$50 - LCA (EACH)
BODY PARTS - OBO
$50 - Trunk
