NOTE: I can ship at your cost.
- M20 b25 bottom end w/ trans. $120
Description: Engine came out of a 90 325ic vert. Never seen it run, so unknown condition. Engine has the accessories and oil pan. No harness or DME. Comes with auto trans. Head was removed and sold locally on craigslist.
- M20 b27 engine w/ trans. SOLD
Description: Engine came out of a 88 325e coupe. Never seen it run, so unknown condition. Engine complete w/ all accessories from valve cover to oil pan. No harness or DME as well. Engine was pulled for a track build.
- M20 b25 block $80
Description: Just the block w/ a couple accessories. No oil pan ect. Just block with the rods and Pistons untouched.
- M20 b25 Auto Trans $20
Description: Trans came off a 88 325is. Shifted excellent. Had around 140k miles.
- Cam Shafts M52 $75
Description: Intake / exhaust cams off a 24v 1997 328is.
- M20 intake manifolds $20
Description: intake manifolds from numerous years, m20 b27 and m20 b25.
- M20 Driveshaft $80
Description: Removed from a 90 325 auto. Has small output flange.
- M20 Driveshaft SOLD
Description: Removed from a 89 325 manual. Has small output flange. Previous owner mentioned that it was rebuilt and balanced.
- HD Rockers SOLD
Description: Removed from a 325i cylinder head. Stronger performance rockers than stock.
- M52 Intake Manifold $40
Description: Removed from a 97 328is.
- M52 Injectors $40
- M50 Oil Filter Housing $60
Description: Removed from a e36 M50 1995 325i.
- M52 Oil Filter Housing $40
Description: Removed from a e36 M52 97 328is.
- ZF Trans $100
Description: 1st and 3rd gear pop out. Removed from 1997 328is.
- M20 Cylinder Heads $80
Description: With valves and valve springs. No cam ect.
- M20 Valve Covers $30
Description: 325e and 325i valve covers for the m20 b25 and b27.
- E36 Oil Pan $60
Description: Rear sump oil pan. Will work on all 24v e36.
- Single Mass Flywheel SOLD
Description: Removed from a 1995 M3.
- M20 Starter $60
Description: Bosch OEM starter in perfect working order. Removed from an 89 325.
- M52 Cylinder Head $150
Description: Nothing is wrong with the head, but I parted the engine out. Head has the valve springs ect. This is for the casting. Price fluctuates depending on what's included. Tensioner ect.
- Exhaust Manifolds $40
Description: Removed from an 1995 m3. S50. They need new studs.
Description: Removed from an 89 325. M20 b25. 2.5L.
- MAFs / AFMs $40
Description: OBD1 MAF removed from an 95 m3. Other MAFs / AFMs that I have range from 325e - 325i models as well.
- E30 Grill Sets $30
Description: 3 piece / section grills. Passenger side, drivers side and middle kidneys. $10 per grill.
- S50 / M50 Cam Trays $40
Description: Removed from 95 M3. Will work in a 325i M50 as well.
- S52 / M52 Cam Trays $40
Description: Removed from 97 328is. Will work in a 96-99 M3 as well.
- E30 Tan Sport Seats $340
Description: Cloth / leather seats out of a 318is I believe. No rips or tears, need to be vacuumed ect. But overall good shape.
- Rear Tan Deck $20
Description: Removed from a 91 325i e30. Rear speaker deck.
- E30 Door Panels (Coupe) $100
Description: Tan door cards removed from 90 325i. Cloth inserts in the middle. No door handles.
- E30 Door Panels (Coupe) $120
Description: Tan leather door cards removed from 88 325. Tan door handles.
- E30 Rear Seat $60
Description: Tan Vinyl rear seat removed from a 88 325. Top and bottom portions.
- E30 Tan Sport Seats SOLD
Description: Removed from 88 325. In actually really decent shape, with the bolsters being fully intact and all adjustments working.
- M20 b25 wiring harness 325i SOLD
Description: No cut wires. Clean harness.
- M20 b25 DME SOLD
Description: Removed from 2.5L 325i.
- M20 b27 DME $50
Description: Removed from 2.7L 325e.
- E30 Rear Trailing Arms $60
Description: Removed from an 86 325es. Will work on all e30 325 models.
- E30 Rear Sub Frame $60
Description: Removed from a 90 325is. Will work on all e30 325 models.
- Windshield Wiper Fluid Tanks $10
Description: Removed from multiple e30 models. Have multiple.
- E30 Intake box $20
Description: Removed from 325e / 325i. Stock OEM air box.
- E30 Coolant Tanks $20
- E30 Rear LSD $200
Description: 2.93 Ratio. Removed from a 86 325es. Unsure on condition, never drove car.
- E30 Rear LSD $200
Description: 2.93 Ratio. Removed from a 88 325. Unsure on condition, never drove car.
- E30 M TECH 1 Sterring Wheel $100
Description: Removed from an 88 325. Missing the 3 steering wheel emblems. Not the BMW symbol, but the stripes on the right, left, and bottom side. Otherwise its in decent shape.
- E30 Sealed Beams $40
Description: Removed from an 90 325i. Inner high beams tinted yellow from previous owner. Great output for sealed beams.
- E30 Cluster SOLD
Description: Removed from a 88 325. 6K super ETA tachometer.
- E30 Basket Weaves SOLD
Description: Decent set of 5 14" Basket weave wheels. Tires probably have 35-40% left on them. No center caps.
& more!
(860)713-4504.
- M20 b25 block $80
- HD Rockers SOLD
- M52 Injectors $40
- ZF Trans $100
- E36 Oil Pan $60
- M20 Starter $60
- MAFs / AFMs $40
- Rear Tan Deck $20
- E30 Rear Seat $60
- M20 b25 DME SOLD
- M20 b27 DME $50
- E30 Rear LSD $200
- E30 Rear LSD $200
- E30 Cluster SOLD
& more!
(860)713-4504.
