swapping to a m60 so i'm selling all of my m20 stuff. all parts came from a manual 1989 325i. will have more pictures shortly. located in Austin, texas. willing to ship most things at buyers expense.
2x m20b25 head (885 casting)
one head is from an overheated m20, everything is intact however i am not sure of condition. $80
second head is in good condition taken from hydrolocked m20. only bottom end damage, no valve damage. perfect for that 2.7 "stroker" $175 SOLDSOLDSOLD
m20b25 ecu
good working condition came from 5 speed car (not sure if matters) $40 SOLDSOLDSOLD
m20b25 fuel rail
good condition, $40 with injectors $20 without SOLDSOLDSOLD
2x oil pan
first pan has a ~2" crack at the back of the sump(i just smeared some instant gasket and it holds lol), gasket seals perfectly $75
second pan has a crack in it causing a slow leak, easy enough to weld, $75
intake manifold
$30
1x throttle bodies
$30 each
alternator
good working unit $40 SOLDSOLDSOLD
starter
never let me down $60 SOLDSOLDSOLD
stainless steel headers
not the prettiest and one of the runners has a little wobble. you will need to get these welded to your stock exhaust however i will include the lengthened o2 sensor. $80 SOLDSOLDSOLD
if you pick up you can take the whole exhaust for free if you prefer (i havent ground off the x pipe yet)
i also have an almost complete 5 speed swap (5 speed transmission g260, selector rod and shifter carier, driveshaft, clutch/flywheel, pedal assembly, brake booster, slave and master cylinders $600 SOLDSOLDSOLD
m20b25 ecu
m20b25 fuel rail
2x oil pan
intake manifold
$30
1x throttle bodies
$30 each
alternator
starter
