Feeler: complete M20 engine in Massachusetts
  • FredK
    • 14764
    I will be doing an engine swap within a few months. Right now it's hot as balls outside so you can understand why my progress is so slow.
    Anyway, the original 1530xx mile 2.5L M20 engine is up for grabs. This is the i engine. $400.
    Complete from airbox to exhaust manifolds, to oil pan. ECU and harness are included.
    No oil in coolant, no coolant in oil. I first performed a compression test but I forgot to hold the throttle body open, resulting in some whack comp numbers. I then performed a comp test after warming up the engine and putting a few drops of oil in each cylinder. Today, I drove the car around for 10 miles to burn off any oil residues, and got the engine to full operating temperature. The no oil comp numbers are shown first, followed by the comp numbers after a squirt of oil.
    Comp test, hot engine, measurement taken after three cranks, performed 8/8/06
    Cylinder 1: 150
    Cylinder 2: 152
    Cylinder 3: 149
    Cylinder 4: 150
    Cylinder 5: 148
    Cylinder 6: 155
    Each cylinder came up to pressure very quickly, probably around 80 psi on the first crank.
    Comp test, warm engine, with squirt of oil in cylinder, measurement taken after three cranks, performed 7/28/06
    Cylinder 1: 180
    Cylinder 2: 175
    Cylinder 3: 172
    Cylinder 4: 170
    Cylinder 5: 172
    Cylinder 6: 170
    The engine runs smoothly and powerfully, though there is a little bit of valve noise. Probably needs an adjustment. Dist cap, rotor, AC, Alt, PS, and timing belt done at 126,321 in Feb 03. The engine leaks oil. Plug wires look newer, there's no ozone decay and the plug boots are dry.
    The engine is still in the car, but I can remove it within fairly short order if you are interested in picking this engine up. Heck I might even remove the engine in a few weeks just so I can marvel at an empty engine bay. :loco:
    You can probably part this engine out and make money, but I'd rather sell it to someone who wants a little more get up and go than a M20B27.
  • MA325is88
    • Mar 2005
    • 580
    where in mass?
    • FredK
      • 14764
      Near Fall River. Probably around a good 2 hours from Chicopee.
      • FredK
        • 14764
        EDIT: I am going to try to sell this engine whole before I part it out.
        • FredK
          • 14764
          BUMP IT UP! for new compression numbers!
          • RedHoodRidah
            • Feb 2006
            • 1096
            If you end up parting it out im interested in the oil pan. Im in Rhode Island which isnt that far. Free bump btw.
            92 Granite Silver Vert
            M60B40 5spd
            • Mike325
              • Mar 2006
              • 3685
              How much oil does it leak? May be interested.
              Originally posted by Kershaw
              • Mike325
                • Mar 2006
                • 3685
                Hmmm, maybe I could come up to your house the check out the running motor before you pull it if I want it. Are you pulling it at your house?
                • Mike325
                  • Mar 2006
                  • 3685
                  Also, is it a stick? That would make the swap easier. As you can tell, I am interested. Three posts in a row lol:loco:
                  Thanks.
                  • FredK
                    • 14764
                    PMed!
                    • MikeK
                      • Jan 2005
                      • 2771
                      still for sale? My step brother's uncle is looking for a motor.
                      Toyota Pickup
                      • M-technik-3
                        • 18946
                        such joker u are mike.
