Parts left from E30 Turbo Build (still in progress)
  • Shubin_e30
    • Oct 2014
    • 19
    Hello everyone,
    Hope everyone is doing well. Today I was cleaning my garage and realized I'm ruining out of room. This is mostly due to my e30 build. A small briefing about my project, I started out with a stock 325e then turned in to a stroker that required a 325i head, intake manifold, throttle body, wiring harness, 325i ecu (with chip) thicker head gasket, 325i crank pulley with sensor, and M50 18Lbs green injectors. This set up was working really good, The power difference was definitely noticeable and worth the upgrade. Me being power greedy and as seeing how easy it was to do the stoker decided to do a turbo build. As this was my first turbo build it took exceptionally long wont be going in to all those details right now but basically once I had everything finished and all I needed was to do a tune on my megasquirt ecu I decided to take my car for a drift... ( Worst Idea of my life..) I blew my motor :((( and had to start all over with another engine. I hope this kind of explains why I have so many left over parts. Anyway Im selling everything thats laying around. Prices for parts will be listed below. Shipping is not included. If you do need me to ship P'm me and I can find out how much it will be to ship to you. I do have a couple other parts that are not listed if there is something you need message me to see if I have it.
    Also with any other questions contact me and Ill do my best to help you out.
    PS: Im thinking about doing a detailed write up of my e30 project (stroker build & turbo build) Let me know if you guys would be interested to hear more about it.
    For some reason I cant upload pictures to this post. Please go to following link to see all parts:
    Parts:
    1.) m20 Exhaust Manifolds (I have 3 sets) one set is painted black ($50.00) each set.
    2.) Front Metal Bumper Absorber (51.11-1986 971) Right and Left sides
    ($50.00) for both
    3.) 325e Instrument Cluster 143k Miles ($80.00) was in working order when pulled from my car. NEEDS NEW GEARS (1 377 313)
    4.) 325e BOSCH ECU (0 261 200 027) with installed Pro Performance Chip ETA. Original chip will be included as with installation manual from manufacturer. ($50.00)
    5.) e30 Gas-A-Just Front Shocks (1 pair) they have about 3k miles on them
    ($60.00) SOLD
    6.) A/C Radiator. NEW never installed. Originally paid $180.00. After turbo I had to get rid of the whole a/c system in order to fit all plumbing for inter-cooler. ($80.00)
    7.) E51 Coil. These are not BWD brand. They are just the extra coils I had laying around. I believe they came out of a Chevy Malibu. I used them in my wasted spark upgrade and they worked perfectly. ($15.00 each or $30.00 for all 3)
    8.) 325e O2 Sensor ($20.00)
    9.) 325e Front Buckle. Not sure if its driver side or passenger. ($25.00)
    10.) Starter BOSCH (0 001 311 125) good working condition ($40.00)
    11.) A/C RECEIVER ($30.00)
    12.) A/C Air Compressor 325e 1986 (DENSO 64 52 1 386 256) ($50.00)
    13.) A/C Air Compressor 325i 1990 (BEHR 64 52 1 377 943) ($60.00)
    14.) BOSCH Alternator (0 120 469 777 779) ($50.00)
    15.) 325e Front Right and Left strut housing assembly ($150.00 for both) SOLD
    16.) 325e Wiring Harness ($80.00)
    17.) 325i ECU (PARTS ONLY) This was a Red label ECU. At the time i destroyed it I had no idea they sold converter connectors to megasqirt ECU's. Basically I pulled out the connector so I could use the cars stock wiring with my aftermarket ECU. This ECU might still be fixable but im selling it as a parts board. ($10.00)
    18.) Dinan Engineering Performance Chip. This chip is specifically tuned for a stroker. It will work on the 325i's but shows better performance out put in the stroker. I bought chip for $200.00 it was definitely worth it. ($150.00)
    19.) Pressure plate (TYP MF 228) and Clutch Release Bearing ($50.00)
    20.) A/C Hoses:
    A.) A/C Compressor Suction Low Side Hose ($30.00)
    B.) A/C Dryer Line Pressure Hose ($25.00)
    C.) A/C Air Conditioning Hoses (x2) ($65.00)
    21.) 325e Radiator Coolant Expansion Tank (1 707 540) ($10.00)
    22.) Upper Radiator Bracket (17 11 1 709 347) ($10.00)
    23.) Mass Airflow Meter Bosch (0 280 202 082) with cold air intake adapter ($70.00)
    24.) Thermostat Housing Assembly with Sensors (1 265 055) ($20.00)
    25.) Center Dash Vent ($20.00)
    26.) Exhaust Manifold Gasket Set slightly used ($30.00)
    27.) Bosch ABS Hydro Unit Module (0 265 200 013) ($30.00)
    28.) 325e Throttle Body with Intake Air Boot (1 285 479) TPS not included ($50.00)
    29.) M20 Air Box Filter Housing (needs new filter) ($30.00)
    30.) 325i Air Intake Boot (1 708 800) ($10.00)
    31.) Power Steering Tank ($10.00)
    32.) Fuel Rail Assembly with Blue injectors and fuel pressure regulator ($70.00)
    33.) Fuel Injectors Set of 6 (0280150415) M50/M52 18lbs used them in the stroker set up. ($60.00)
    34.) 325e Spark Plug Wires ($30.00)
    35.) 325e Ignition Coil ($20.00)
    36.) Distributor Cap and Rotor (3 total) one is missing plastic cover. ($35.00 each and $30.00 for the one with no cap)
    37.) Thermostat alloy housing with attached part ($30.00)
    38.) 325e Idle Control Valve (1 707 395) ($70.00) note: this dose not include the cap from air intake manifold and sensor.
    39.) Pulleys:
    A.) Crank Shaft Hub Belt Pulley (x2) (1 280 958) ($20.00) each
    B.) Water Pump Pulley (1 272 946 W+P) ($15.00)
    C.) Water Pump Pulley (1 271 424 W+P) ($15.00)
    D.) Balancer Crankshaft Pulley (1 726 351.1) ($35.00)
    E.) 325e Balancer Pulley (1 705 764) ($45.00)
    40.) 325e Headlight H1 Bulb ($10.00)
    The rest Im not going to list. If you see something thats not listed message me and Ill get price for you. Last pictures are of the 2 motors I salvaged. I can pull parts from them also. Just let me know what you need.
    Thanks
    -Alex
  • Shubin_e30
    • Oct 2014
    • 19
    Bump:D
