Thanks everyone buying parts so far!
Located in East Atlanta.. Pickup prefferred. Prices below are without shipping. Pics available. I accept payment through Square Cash or check/MO.
**Currently looking for an affordable M20B25 long block or bottom end in Atlanta, GA area preferably**
-Red46 Sump Armor M20 Skid Plate $120 (complete new in box)
-Powerflex E30/Z3 Urethane Differential Mount $40 (new in pkg)
-IE Urethane Steering Coupler $20 (brand new in pkg)
-Meyle Brake Lines New in pkg p/n 300 343 2106 & 300 343 2100 $15/each
-Hirschmann Power Antenna 100% complete and working $100
-Pass Side taillight assembly -no cracks but not pristine $50
-Motometer Instrument Cluster with Bezel and lower trim 7k redline $65
-pair felt trunk liners $40
-325i Valve Cover $30
-M20B25 Exhaust Manifolds $40
-Late 325i low mi. Bosch Starter $100
-E-Brake boot $5
-8/10 Glove compartment $10
-Glove box latch $10
-power mirror adjuster/switch $20
-outside door handles (painted) $20
-radiator top bracket $10
-Passenger side Euro grille. $20
-Late e30 325i Brake Booster $30
-2 Late style 325i fuel pumps single inlet 1 with fuel level sender/one without $50/60/ea.
-Intake plastics with inlet $30
-Like new intake boot from an 89 automatic (match yours) $10
-3rd brake light $5
-Hood release lever and latch no cable $20
-Late e30 325i Bosch Alternator $60
-Complete copper trunk mount battery cable (runs length of chassis)$60
-Front wheel well plastic liners not perfect $20
-rock shield with crossmember $20
As is T Stat housing/coolant body $15
-Late style e30 electric mirrors non sport $30/pair
-Lower steering column cowl piece airbag cars part no. 1 156 481 1 $5
-m20 timing cover $10
-cig lighter, imprint has wear $5
-Like new 80 degree thermostat $15
-e30 Ignition lock cylinder with Key $20/ea
-Bosch ignition coil from running 91 325i $10
OEM steering wheel small roundel logo $5
-OEM Check panel $15
-Blank insert plug from roof valance $5
-Cooling fan with newer fan clutch $40
-Headlight switch with panel trim $10
(2) brake light switch $5
-Hazard Switch $5
-(10) OEM Relay 61.31 1 375 474 $5
-OEM Purple relay 373 602.3 20 211 001 $5
-metal wiring loom support under manifold $10
-metal support bracket for motronic connector $10
-L-Shaped late e30 Idle Control Valve ICV
-Misc OEM BMW Hose Clamps $3/each
-Late e30 Facelift Plastic Bumper inner frame assembly w/brackets $40
-charcoal grey fabric section, across base of rear seat from 4/dr. $10
-e-brake console 7/10 would clean up $15
-ignition steering column trim from airbag car Part no. 1 155 103.0
-hood support and shock 7/10 $10
-stock 325i front spring hats $5
-E-Brake boot $5
-3rd brake light $5
-Hazard Switch $5
