Located in CT. Local pick-up is available. Shipping is also available on your dime. Your cover paypal fees or send as friends and family.
- Custom e30 24v turbo manifold built by "Slighty over-built" / Fabricator at Maximum Psi.
T4 Twin-scroll, twin tial 38mm MVS gates. Will include the 2 external dump tubes that go off the gates. $1500 manifold that has been proven to hold over 1000whp. SOLD
- CP Carillo pistons with HD wrist pins, 86mm, 10.5:1 for use with an s52 / M54 B30 crank (LIKE NEW, absolutely flawless, 400 miles) Will come with a brand new in box set of piston rings for your install. There is over a month wait for the pistons! $1450 new. My price $800.
- Pauter Extreme Duty rods for a e36 engine. All within spec. (LIKE NEW, absolutely flawless, 400 miles) $1400 new. My price $1100.
- M54 B30 / S52 crank in excellent shape $250.
- Gold Authentic Tial 50mm Bov (Used, works perfect) SOLD
- Megasquirt v3 pro standalone with complete wiring harness plug & play, besides you pinning your c101. Comes with a AEM wideband gauge / sensors that you need for install. Will also come with a MAC solenoid wired into the harness. All you need to do is hook up the wastegateag lines to it and your good to go! Very straight forward for someone who isn?t looking to take the time to make there own harness ect. $1200. For an additional $100 I can include the M50 manifold listed below.
- M50 intake manifold (Has 2 tapped fittings for the megasquirt / FPR as well as a blocked off ICV port) $100.
- AEM Meth kit, pump, tank, nozzle. Worked perfect, still installed in car. (Controlled through megasquirt) $300.
- Aeromotive FPR $70
- CES cutring head gasket with copper spacer. For M52 engine. Excellent shape (Used for 600 miles) Paid $500, My price $300.
- ARP E36 head studs (Used. All within spec) $100.
- 60lb injectors (1 of them is missing the tip, got lost during removal. SOLD
- (2) M52 bare block $150 each.
- S52 cams (a couple of the journals do have slight scoring, but they worked fine) SOLD
- E36 cylinder head that has been gone through, new valve stem seals, cleaned ect. Will need to be resurfaced to skim off where the cut-ring head gasket pressed in. $225.
- E36 cylinder head, will need to be cleaned / resurfaced before install. $200.
- E36 vanos unit $50.
I will be adding parts to this list throughout the week.
