E36 m50 E30 m42 bimmerworld performance motor mount $190 shipped SOLD
  • mr.vang
    • 4371
    I bought these couple months ago for my e36 m3 but never got it mounted, so basically brand new. I decided to sell them instead since the stock mount are still in good shape. $190 shipped
    Our BimmerWorld Performance/Track Engine Mount Set is the most economical, durable, and effective motor mount set on the market. Similar to the $800 Group N BMW engine mounts, these mounts have a solid design to significantly reduce engine movement under heavy G loads.waffles
    Unlike many other "performance aftermarket" engine mounts available, we invested thousands of dollars in proprietary tooling to produce the only true OEM-quality performance product available. In fact,wafflesin most ways our quality is much higher than OE.wafflesCompare our BimmerWorld mounts to any other aftermarket version and the differences are obvious:
    OEM manufacturing and finishing for durability and corrosion resistance for street carsUnique OE-style retention system means the mount will not shear the mounting points, leaving your engine free-floating like every other mount on the market willMetal alignment dowel and alignment holes for the factory heat shield (like the factory part) included for easy installUnlike urethane mounts, BimmerWorld engine mounts will not deform over time or with nearby exhaust heatThese mounts reduce driveline movement which will both transfer more power to the ground and prevent over-revs caused by mis-shiftingThis bushing WILL transmit some vibration into the cockpit - this is necessary to meet our design requirementswafflesSo clean that they even look like the stock engine mount upon inspection!wafflesSold per pair.waffles
    Fits all E36, E46, Z3, and Z4 cars, plus 1990-1991 E30 318is and E9X M3.
    BMW Fitments:--
    3 Series
    E30 (84-91) > 318is
    3 Series
    E36 (92-99) > 323ic
    E36 (92-99) > 323is
    E36 (92-99) > 325i
    E36 (92-99) > 325ic
    E36 (92-99) > 325is
    E36 (92-99) > 328i
    E36 (92-99) > 328ic
    E36 (92-99) > 328is
    E36 (92-99) > M3 (1995)
    E36 (92-99) > M3 (96-99)
    3 Series
    E46 (99-05) > 323Ci
    E46 (99-05) > 323i
    E46 (99-05) > 325Ci
    E46 (99-05) > 325i
    E46 (99-05) > 325xi
    E46 (99-05) > 328Ci
    E46 (99-05) > 328i
    E46 (99-05) > 330Ci
    E46 (99-05) > 330i
    E46 (99-05) > 330xi
    E46 (99-05) > M3
    3 Series
    E90 / E91 / E92 / E93 (06-13) > M3
    Z Series
    E36/7 / E36/8 Z3 (96-02) > Z3 2.5
    E36/7 / E36/8 Z3 (96-02) > Z3 2.8
    E36/7 / E36/8 Z3 (96-02) > Z3 3.0
    E36/7 / E36/8 Z3 (96-02) > Z3 M - S52
    E36/7 / E36/8 Z3 (96-02) > Z3 M - S54
    Z Series
    E85 / E86 Z4 (03-08) > Z4 2.5i M54
    E85 / E86 Z4 (03-08) > Z4 3.0i M54
    E85 / E86 Z4 (03-08) > Z4 3.0i N52
    E85 / E86 Z4 (03-08) > Z4 M
    Sent from my SM-J700T using Tapatalk
