BMW E30 Parts From 1987 E30
This car was in the process of being upgraded and rebuilt when I bought it. A lot of new and refurbished parts had been installed when I bought it. The engine had not been installed so the car had not been driven since the parts were installed. The car was a 1987 BMW 325 4 door sedan.
(SOLD) Medium case 188mm LSD Differential with about 175K miles. Clean and no known defects. $350. (SOLD)
(SOLD) Front stabilizer bar - 21mm with new bushings and links - $50.
Rear stabilizer bar - stock with new bushings - $40.
(SOLD) Rear wheel hubs - $50 for pair.
Rear trailing arms with new bushings - $50 for both..
Front lower control arm bushings and brackets. Bushings are offset and were installed new. $50. for both.
Parking brake cables - installed new. - $35. for pair
Front lower control arms - good used condition - $40. for both.
Battery relocation cable - complete full length cable from trunk to firewall - $50.
(SOLD) Metal headlight buckets with sealed beams. Condition of bulbs unknown. - $40 for both.
In-tank electric fuel pump with fuel level sender. For earlier tanks with single opening. Pump tested but sender untested. - $50.
(SOLD) Rear polyurethane sub-frame bushings - installed new. $40.
(SOLD) Front and rear brake calipers. Front are Girling and rear are ATE. Brake pads have little or no wear and car probably has not been driven since they were installed. $100. for all four.
I also have an M50B25TU single VANOS long block that started out as a stroker project. I will part out the engine. The E34 front sump oil pan is sold but the following parts are available:
Complete long block with cyl. head, pistons, rods and crankshaft $300.
***Will Part Out***
Stock pistons and rods - $150 for all 6 sets.
Stock crankshaft - $150.
Engine block - $100.
Oil pump with front sump pick-up tube - $50.
Windage tray and dipstick with tube - $40.
Cylinder head - Make offer.
M50 intake manifold with throttle body $100.
Engine wiring harness $75
Bosch Red Label 413 ECM/DME. Has note that Technica chip installed. $75.
Misc. brackets, oil filter housing, valve cover, alternator, ps pump, etc.
These parts are available for pick up at my residence in Clermont, Georgia. which is located between Gainesville and Cleveland just off of US Hwy 129.
Shipping is at purchaser's expense. Please do not use the Panjo checkout but contact me before making payment.
Text 678-936-1966 for more information or sent email to jrobertson24@bellsouth.net.
List Date: 4/21/2017
For more info, click here to view the original listing: BMW E30 Parts From 1987 E30
This item is no longer available.
***Will Part Out***
