I have a few sets in stock ready to go!
E30 Recaro Seat Brackets
Hi, these still haven’t worked out for me. We took care of the 4 hole vs. 6 hole mounting,
But after following the instructions and photos, the stock slider rubs against this bracket. I noticed with the other brands, it’s cutout, shaped to have enough clearance. How exactly do you have yours mounted to clear the slider lever from being pinched?Comment
I don’t have them to take photos, I sent them to a machinist to cut them.
When you mount yours, does it retain the sliding function for both rails at the same time?
I tried 101 different ways to mount them but because they are bulky, they rub on the lever right at the release function for the slider.
When you look at other known Recaro bracket here, it’s thinner in the middle to clear the lever arm.
I have to have it modified to work, how are you mounting yours to clear the slider lever? Closest I got was lever side stayed pinched in the unlock slide position while the opposite stayed locked.Comment
Yes, mine function perfectly. I haven't had any negative feedback from anyone, so I haven't had to look into any potential issues or areas for improvement. I'd love to be able to see what's going on so that I may be able to address this. I've been thinking of trying to add some mounting points for other seats, so I could alter my design if necessary.Bryan - 1989 325i S50 swapped /1990 Audi Coupe QuattroComment
I'd have to see the bottom to give you a definitive answer, but you purchased a set and they're on their way to you. I'm 95% sure those will work based off of their look and vintage.
Thank you for your purchase!Bryan - 1989 325i S50 swapped /1990 Audi Coupe QuattroComment
