BMW E30 Drool Worthy Engines for Sale, Other parts as well
  • Tubby
    • Aug 2013
    • 18
    Hi All,
    Selling off some BMW E30 stuff that was built for endurance racing. We have moved in a new direction so we are liquidating the E30 spares.
    - Rebuilt M20 engine. Cryo-treated and complete with harness. The engine has run two race weekends and it runs very strong. The leak down numbers are 1 – 6%, 2 – 6%, 3 – 7%, 4 – 6%, 5 - 7%, 6 – 5%. We have $4200 in new parts (see below) and machine work. Sale price $2900.00. Expensive vs. a junkyard engine but much cheaper than doing it yourself. These motors were built and ran with a stock BMW DME.
    TPIS Rebuild includes complete valve job, crankshaft polish, cylinder hone, new main bearings, new rings, Head and block magnufluxed for cracks and both were in excellent condition. $1535.65
    Cryo Treating $600.00
    11 33 1 258 327 – Washer
    11 42 1 265 376 – Pipe
    07 11 9 942 079 - Dowel Pin
    07 11 9 915 093 - Hex Bolt
    11 31 1 272 433 – Screw
    11 12 1 726 241 – Dowel
    11 42 1 271 318 - Relief Valve $54.10
    11 42 1 271 320 – Piston
    11 41 1 744 324 - Compression Spring
    11 14 1 716 134 – Bracket
    11 23 1 726 961 - Vibration dampener $278.45
    11 42 1 711 070 - Oil Filter Head $234.43
    11 42 9 059 338 - Gasket Set
    17 21 1 719 194 - Oil Cooler Pipe $84.42
    17 21 1 719 193 - Oil Cooler Pipe $110.58
    11 31 1 716 138, Camshaft $149.21
    2C4762 - Ring Pack $106.85
    2C4762.020 - Ring Pack $106.85
    11 42 1 711 071 - Hollow Bolt
    11 31 1 715 412 - Torx Bolt
    11 21 1 706 849 - Main Bearing Set $97.70
    Ireland Eng. Windage tray & oil pan baffle $104.79
    Injector blue printing $194.70
    11 53 1 466 174 – Thermostat
    11 51 9 070 759 - Water Pump
    11 31 1 713 064 - Cam Gear Adapter
    11 31 1 717 180 - Cam Gear Washer
    11 12 1 265 087 - Cam Guide O-Ring
    11 11 1 730 875 - Crankcase Gasket set
    17 20 1 719 262 - Oil Cooler $244.55
    11 42 1 265 670 - Oil Filter Adptr O-Ring
    11 41 1 720 898 - Oil Pump $148.35
    11 41 1 267 796 - Oil Pump Shaft
    11 31 1 267 746 - T-Belt Tensioner spring
    11 31 1 280 960 - Tensioner Roller Belt
    11 33 1 744 355 - Valve Adjust Bolt
    11 76 1 711 717 - Exhaust Flange Gasket
    07 11 9 963 441 - Oil Filter O-Ring
    07 11 9 963 384 - Oil Filter O-Ring
    11 31 1 713 475 - Timing Cover
    12 61 7 620 512 - Oil Pressure Sender
    11 42 1 714 764 - Oil Filter O-Ring
    17 22 2 245 358 - Oil Cooler Seal
    11 33 1 744 333 - Valve Adjust Nut
    11 33 1 744 354 - Valve Adjust Eccentric
    TB 131 K1 - Timing Belt Kit
    11 42 9 059 338 - Oil Relief Valve kit
    12 61 1 277 602 - Oil Level Sender O-Ring
    11 12 9 059 240, Cylinder Head Gasket Set $75.60
    11 12 1 726 478 - Cylinder Bolt Head Set
    11 53 1 730 470 -Thermostat Housing $49.23
    07 11 9 919 228 - Thermostat Housing Plug
    RAL 14X18 - Seal Ring Aluminum
    11 53 1 265 059 - Thermostat Housing Cover
    11 53 1 275 881 - Coolant Bleed Screw
    Heater replacement plug set
    Total cost for rebuild not including assembly was $4175.47
    - Our Second engine has all the same new parts installed but has a leaking head gasket and most likely overheated. Will sell for $900.00. We built both of these engines at the same time in parallel.
    Other parts we have that are being liquidated:
    - E30 Light weight flywheel (Clutch Masters FX400 Clutch Kit - 03010-HDC6) with new heavy duty JB Racing clutch. $650.00 - Sold
    - BMW E30 Rebuilt drive shaft. $350.00
    - Rear sub frame assembly with trailing arms, Spec E30 camber/toe adjusters, newer output shafts, stock bushings, wheel bearings, SS brake lines, newish calipers, rotors. $750.00.
    PM me with questions.waffles All items are located in Burnsville, MN.
  • jwhuffandpuff
    • 26
    Any chance you have a water pump Pully for an 88+?
    • Tubby
      • Aug 2013
      • 18
      Yes! Best option for you is to buy the motor and you get the pulley for free.
      • Tubby
        • Aug 2013
        • 18
        Pics of the $900 motor needing a head gasket.
        This motor ran two race weekends podiumed at both events.
        • samurai7
          • 428
          Savage! :devil: Lol
          Originally posted by nervousmini
          Break My Wallet
          Bring My Wallet
          Bring Money With
          and the M cars are a multiplier
          regular repair Money * 3 = M3
          regular repair Money * 5 = M5
          regular repair Money * 6 = M6
          • Tubby
            • Aug 2013
            • 18
            Just quoted a price to ship a motor to New Jersey from Minnesota for $136. Pretty cheap if you're not in MN.
            • DaWildBeast
              • Mar 2016
              • 244
              E30 Austin might have one he would be willing to sell...
              • jwhuffandpuff
                • 26
                I have too many motors and not enough pulleys! Dang it.well if you don't get too many bites on the motor, PM me please and I will be glad to take it off your hands!
                GLS
                • jwhuffandpuff
                  • 26
                  Thank you!
                  Edit. User search coming up empty on that name
                  • DaWildBeast
                    • Mar 2016
                    • 244
                    My bad his name is Austin! On the forums
                    • Tubby
                      • Aug 2013
                      • 18
                      Clutch and flywheel Sold!
