I don't have pics here for every single item but can take more pics. I hope linking the Flickr album is OK. If not I can post individual pics.
Shipping is from Blaine, Wa 98230 or pickup in South Surrey, BC. Paypal preferred.
M54B30 Vanos assy. $40
M54B30 Oil pan $30
M54B30 Oil filter housing assy. $25
M54B30 engine wiring harness. $40
M54B30 thermostat. $10
M54B30 knock sensors. $20
M54B30 cam trays with caps and hydraulic lifters. $40
M54B30 dipstick tube and dipstick. $20
M54B30 timing chain cover. $20
M52B28 oil pan. $30
M52B28 oil dipstick tube. $10
M52B28 engine harness. $40
M52B28 Oil filter housing. $20
M52B28 Oil filter housing gasket, brand new. $10
M52B28 Throttle body assy. $25
M52B28 ASC throttle . $10
M52B28 fuel rail. $10
M52B28 OEM exhaust manifold/headers. 1 or 2 studs need replaced. Upgrade for older E36 6Cyl. $50
M50B25tu fuel rail with brand new regulator. $40
M50B25tu OBD1 Bosch ignition coils with boots (x6). About 20,000 miles. $80
M50B25tu coolant hoses. Almost every hose under the hood. All about 20,000 miles. $40
M50B25tu valve cover, aluminum thermostat cover, aluminum OFH cover, powdercoated bright orange. $100
E36 6 Cyl rear main crank seal with metal gasket. Brand new. $10
E36 6 Cyl aluminum theormostat covers. One $15, one $10.
E36 6 Cyl oil pump pickup tube, reinforced (Z3). $50
E36 6 Cyl silicone rad hoses. $30
E36 6 Cyl starters. One threaded $30, one not threaded $25
E36 6 Cyl Valeo 80amp alternator. $30
E36 6 Cyl radiator overflow bottle with cap, both about 20,000 miles $30
E36 6 Cyl ICVs. Both in good working condition. $20 each
E36 6 Cyl UUC Motorwerks underdrive water pump pulley. $20
E36 6 Cyl thermostat 80c. $10
E36 6 Cyl Koyo Racing aluminum radiator. $125
E36 6 Cyl Glyco std size full main engine bearing set. Some bearings damaged in shipping. $25
E36 Coupe/Sedan rear subframe bushings - Powerflex Purple version. $60
E36 328is ABS controller. $20
E36 328is ASC controller. $20
E36 328is passenger side aribag. $20
E36 Coupe doors. Good condition. Stripped. $20 each. 1993 325is Maritius Blau color.
E36 Coupe center console armrest. Beige leather. $30
E36 GTR style ABS plastic hood vent inserts. Like this: https://www.ebay.com/itm/BMW-e36-e46...-/282170496474 $60
E36 4 Cyl (318i, 318is, 318ti) driveshaft. 2 of them. $25 each
E36 4 Cyl (318i, 318is, 318ti) blue silicone rad hoses. Brand new. $30
E36 4 Cyl (318i, 318is, 318ti) rear axles. 2 pair. $40 each pair
E36 4 Cyl (318i, 318is) rear differential cover with good bushings. $20
E36 4 Cyl (318i, 318is) rear complete differential, 3.45:1 ratio, non-LSD. $50
BMW 168mm 3.23:1 rear diff ring and pinion. $40
Momo shift knob. Missing Momo logo. One on left: https://www.momo.com/en-us/product/r...r-aluminum-us/ $20
Red anodized aluminum 2" steering wheel spacer. Bolt pattern for Momo/OMP, etc... steering wheels. $25
MSD 6A ignition booster box. Wires are cut short, but super easy to extend. $40
MSD stand alone rev limiter box. Wires in between coil and igniter. Needs rev limit pills to work. $30
Tilton lever style brake proportioning valve. $30
Honda/Acura K20A2 complete intake manifold (no TB). $40
Honda/Acura K series Wiseco K631M865 K20 9.6:1 compression pistons. Used but with brand new rings. Comes with wrist pins and wrist pin locks. $350
M54B30 Oil pan $30
M52B28 oil pan. $30
