M50, M52, S52, M54 adjustable cam timing blocks
  • someguy2800
    • May 2013
    • 30
    I've started producing these 3D printed cam timing blocks. They work on all M42, M50, M52, S50, S52, M54 engines.
    Works just like the factory timing blocks but have built in angle for 0-15 degrees of advance or retard so you can adjust both intake and exhaust to any centerline you like. They snap onto the back of the cams and will not fall off. They are reversible so, one side of the block advances the cam, the other side retards the cam.
    The non vanos blocks are for installing a non vanos intake cam into the exhaust side of the head for a cheap upgrade over M50 cams. Paired with an M54B30 intake cam retarded about 8 degrees makes for a very cheap and easy cam upgrade.
    Pricing
    $25 each (minimum of 2)
    $120 your choice of 6
    $150 full set of 10
    Free shipping on everything. For international orders I will do my best to do free shipping or to keep it as cheap as possible. I should be able to do free on most international orders.
    If you want a different color or a custom angle please send me a message, that is no problem. Anything from 0-40 degrees will be easy to make.
    Please PM me if you would like to order some
    86 325es, built 2.8L non vanos m50, borg warner s366, megasquirt 2, ford 9 inch rear end with 4 link, 325 drag radials, T56 magnum trans, mantic twin disc clutch, zip ties, tape spray paint
