I have a custom e30 front big brake kit. I bought this setup from a member on here and have yet to use them.
It consists of modified MG slotted rotors with 4 piston Mitsubishi 3000GT calipers. The calipers use a rx7 adaptor to bolt up to the stock spindles. They also have the correct adapter fittings to tie into the stock brake lines. They PO said the pads that are in the calipers are hawk and the extra pads are unknown.
As seen in the photos, the rotors are a massive 12 inches (305mm) and the calipers stick out approximately 2 inches (51mm) from the rotor hat.
I test fit them with my 16" wheels and they fit with plenty of room. You could probably fit them under some 15s depending on the design. They will obviously need spacers to clear the calipers. I would not run this setup without a proportioning valve or bigger rear calipers.
This setup is fully bolt up and ready to go.
$250 OBO + shipping. Local pickup preferred. Willing to meet up within reason.
*price change* Total weight for everything comes to about 55lbs. Two medium USPS flat rate boxes would be cheapest - at $25 total.
Let me know if you have any questions. Thanks
